Vaughany Posted May 2, 2005 Share Posted May 2, 2005 The fan that sits behind the front bumper in front of the radiator, I believe this is the Air Con Fan. If my understanding is correct this only comes on when the coolant temperature goes above 98 degrees celsius or when the A/C pressure rises to high. Is this correct or should this fan be on all the time when you the air con is on The reason I asked is that I turned on my air con and it is not very cool and I am wandering if this has anything to do with this fan as mine is not spinning. Also does anyone know where the fuse for this fan is located? Cheers Link to comment Share on other sites More sharing options...
MONKEYmark Posted May 2, 2005 Share Posted May 2, 2005 i had to take my fan out when i fitted fmic. was never as cold after i took it off. could it not just need re gassing, seems to work for other people Link to comment Share on other sites More sharing options...
absz Posted May 2, 2005 Share Posted May 2, 2005 If my understanding is correct this only comes on when the coolant temperature goes above 98 degrees celsius or when the A/C pressure rises to high. yep that is also my understanding that the fan only comes in when the pressure rises on the high side, due to temp increase Link to comment Share on other sites More sharing options...
Vaughany Posted May 2, 2005 Author Share Posted May 2, 2005 Cheers guys for the info, maybe I need a re-gas but I am fitting a FMIC very soon, can this fan not stay aswell? Link to comment Share on other sites More sharing options...
MONKEYmark Posted May 2, 2005 Share Posted May 2, 2005 its quite a bulky thing. suppose it depends what fmic you got the blitz one was pretty thick core Link to comment Share on other sites More sharing options...
Vaughany Posted May 2, 2005 Author Share Posted May 2, 2005 I am having the HKS Type R Injtercooler fitted so this fan will probably have to be removed then. Leon from JPS is doing my single conversion so I am sure he will know if it can stay or if it has to go. Link to comment Share on other sites More sharing options...
