where can i get or are these ok?
a98pmalcolm
Hay all...im thinking of getting a new lamber sensor as previous discussions proved that my MPG is terriable and this could assist me in saving a few dibblets in the long run.
Now problem is non of the motor factors in my area have one for my 1993 MKIV Twin Turbo 3L Imported Supra. So only option in my area is toyota and they want around £230 OUCH!
But i have noticed this on e-bay these.. but i dont know if its any good or the correct fitting?
http://cgi.ebay.co.uk/Lambda-Sensor-Toyota-Corolla-Hilux-Land-Cruiser-Prius_W0QQitemZ140319267720QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item20abae1b88&_trksid=p3286.c0.m14
but i know there is a few good traders on here like Chris Wilson and Kerron etc.....But does any one know if anyone sells lambda sensors?
Thank as always
Paul
Fwiw, with engine related sensors, 02 sensors, camshaft, crankshaft sensors, MAF sensors etc its always crucial to use OEM units as these will only be the ones that are correctly calibrated to the required specs.
Usually if you buy any other brand of sensor then it will not be calibrated to the same spec so you will end up paying twice over anyway.
This doesn't apply to O2 sensors as they are all the same bar the heaters, so using universal type will make no difference.
