Nic Posted October 9, 2009 Share Posted October 9, 2009 Nic.. I believe that is not in my car.. So i guess its decatted.. Lolol.. Both? Double check you don't have the 1st cat still in place, it goes up toward the engine and can be a bit difficult to see looking under the car. Link to comment Share on other sites More sharing options...
Nic Posted October 9, 2009 Share Posted October 9, 2009 If the first cat is there.. How would i go about getting it removed.. And will i pass emissions inspection?.. And if i leave it,, can i not go bpu?.. I'm not sure what emission regulations you have in the US, but in the UK a Supra will usually pass the emissions test with only the 2nd cat fitted. The 1st cat is the most restrictive of the 2 so if needs be you can just run with the 2nd cat fitted. Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 i just ran to the garage and i looked through the engine bay and didnt see any cat and checked again underneath and its one 3 inch pipe going to the rear near the differential then joining to the hks exhaust... so all i will need is a fcd, fuel pump, boost controller, and colder plugs and im at bpu level??.. but i plan on installing a fmic with piping.. and pulleys.. what times should i be running?.. and actually,, what times should i be running now with the exhaust, decat, and hks bov..??? Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 im becoming a member,, you guys are soo helpful and awesome.. Link to comment Share on other sites More sharing options...
tony tt Posted October 9, 2009 Share Posted October 9, 2009 i just ran to the garage and i looked through the engine bay and didnt see any cat and checked again underneath and its one 3 inch pipe going to the rear near the differential then joining to the hks exhaust... so all i will need is a fcd, fuel pump, boost controller, and colder plugs and im at bpu level??.. but i plan on installing a fmic with piping.. and pulleys.. what times should i be running?.. and actually,, what times should i be running now with the exhaust, decat, and hks bov..??? Nic mentioned the u.s spec had a larger fuel pump already mate so you may not need that. bpu supra times down the strip i would say low 13,s 13.1 if your good Link to comment Share on other sites More sharing options...
Nic Posted October 9, 2009 Share Posted October 9, 2009 i just ran to the garage and i looked through the engine bay and didnt see any cat and checked again underneath and its one 3 inch pipe going to the rear near the differential then joining to the hks exhaust... so all i will need is a fcd, fuel pump, boost controller, and colder plugs and im at bpu level??.. but i plan on installing a fmic with piping.. and pulleys.. what times should i be running?.. and actually,, what times should i be running now with the exhaust, decat, and hks bov..??? Don't think you'll see the 1st cat looking in the engine bay, as it is buried underneath the turbos, you'll have to get right under the car to be able to see it. You don't need a fuel pump the US spec pump flows more than the JDM and should be fine. You'll need Decat Pipe(s) Spark Plugs FCD Boost Controller Link to comment Share on other sites More sharing options...
Zofix Posted October 9, 2009 Share Posted October 9, 2009 WOuw! wait! if it is a US-spec it is a totally differant story... install a boost gauge and a boost cut controller, and you should be ready to go... forget about restrictor ring and upgraded fueling if you have a US-spec.. Link to comment Share on other sites More sharing options...
Zofix Posted October 9, 2009 Share Posted October 9, 2009 Don't think you'll see the 1st cat looking in the engine bay, as it is buried underneath the turbos, you'll have to get right under the car to be able to see it. You don't need a fuel pump the US spec pump flows more than the JDM and should be fine. You'll need Decat Pipe(s) Spark Plugs FCD Boost Controller Sorry for hijacking, but I have a US-spec with these mods and I boost 1.3bar without a boost controller, Is it possible for me to restrict it more to maybe 1.0-1.1bar? without installing cats again? I never heard of US/EU-spec used restrictor rings Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 the car as of now has a hks drager exhaust,, no secondary cat definitely.. i have to double check to see if the 1st cat is there.. it has a hks seq bov.. and greddy boost, exh temp and oil press gauges.. thats it.. so all i need to do is decat the 1st pipe.. boost controller,, fcd??? and colder plugs?.. im also next week putting a fmic with piping, and intake.. DEFINITELY.. Link to comment Share on other sites More sharing options...
Nic Posted October 9, 2009 Share Posted October 9, 2009 Sorry for hijacking, but I have a US-spec with these mods and I boost 1.3bar without a boost controller, Is it possible for me to restrict it more to maybe 1.0-1.1bar? without installing cats again? I never heard of US/EU-spec used restrictor rings A US Supra shouldn't boost to 1.3bar without a boost controller, it should be around 0.8-0.9bar. Are you sure you don't have a manual boost controller (bleed valve) fitted in the engine bay? Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 Nic.. I just took the car literally down the block.. I left it running,, got it nice and warm.. And i gunned it.. And it hit 1.2 bar?!?!?.. All i have is exhaust, no 2nd cat and a bov... Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 Whats up with that,, is my gauge messed up?.. Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 Sorry 1.1 bar.. Link to comment Share on other sites More sharing options...
Nic Posted October 9, 2009 Share Posted October 9, 2009 the car as of now has a hks drager exhaust,, no secondary cat definitely.. i have to double check to see if the 1st cat is there.. it has a hks seq bov.. and greddy boost, exh temp and oil press gauges.. thats it.. so all i need to do is decat the 1st pipe.. boost controller,, fcd??? and colder plugs?.. im also next week putting a fmic with piping, and intake.. DEFINITELY.. Yes just decat, FCD, plugs (see HERE) and boost controller. If you're buying a FMIC, go for a decent quality one, not some cheap thing of ebay. Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 Ohh shit i do have a boost controller lmfao!!!!!!! Its a lil knob thingy.. Hahahahhahaha Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 I was actually opting for a ebay kit.. Lol.. There no good?.. Link to comment Share on other sites More sharing options...
Nic Posted October 9, 2009 Share Posted October 9, 2009 Whats up with that,, is my gauge messed up?.. Without an FCD fitted it cannot boost over 1bar as the ECU would cut the fueling. Either the gauge is reading wrong or you already have an FCD and boost controller fitted. Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 Ima retard.. I cant believe this,, i get in the car.. Im talking to you guys.. I go shop around for a boost controller.. And i have one.. I just bought the car so i know squat.. It hit 1.1 bar Link to comment Share on other sites More sharing options...
tony tt Posted October 9, 2009 Share Posted October 9, 2009 Ohh shit i do have a boost controller lmfao!!!!!!! Its a lil knob thingy.. Hahahahhahaha Back to the drawing board eh LOL Link to comment Share on other sites More sharing options...
tony tt Posted October 9, 2009 Share Posted October 9, 2009 Ima retard.. I cant believe this,, i get in the car.. Im talking to you guys.. I go shop around for a boost controller.. And i have one.. I just bought the car so i know squat.. It hit 1.1 bar Are you able to get in touch with the guy you bought it from and see what else they had fitted it might save you a lot of hassle. Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 THEN HOW COME IM RUNNING SO SHITTY AT THE TRACK?.. MY LAUNCH IS HORRRIBLE,, IM TRYING TO FIGURE OUT HOW TO BUILD BOOST OFF THE LINE AND CANT,, IF YOU WATCH THE VID I RUN THE FIRST TIME.. AND A COUPLE RUNS AFTER,, NOTCE HOW YOU DONT HERE MY CAR COME ON LINE FOR A WHILE AFTER THE 60 FOOT,, THEN ITS MOVING.. I HAVE TO HAVE A SHOP LOOK AT IT AND TELL ME WHATS IN IT.. FOR ALL I KNOW THE THING GOT A T88.. JK.. http://www.youtube.com/watch?v=GiA5kQSZLco Link to comment Share on other sites More sharing options...
kslb Posted October 9, 2009 Share Posted October 9, 2009 My wifes supe is a stock JDM tt manual only mods are exhaust (cats still fitted) and an HKS ssqv and it runs in the 13's on the 1/4. Link to comment Share on other sites More sharing options...
Zofix Posted October 9, 2009 Share Posted October 9, 2009 A US Supra shouldn't boost to 1.3bar without a boost controller, it should be around 0.8-0.9bar. Are you sure you don't have a manual boost controller (bleed valve) fitted in the engine bay? I'm 100% sure I have no boost controller, my car was 100% stock when I bought it. Maybe it is because of the cold weather in EU? My mod list: HKS FCD HKS super dragger + decat pipe Blitz sus air filter HKS SSQV Greddy spec M FMIC and my DEFi boost gauge shows 1.3 on highway pulls Link to comment Share on other sites More sharing options...
95SupraTT Posted October 9, 2009 Author Share Posted October 9, 2009 Lolol.. I cant believe this.. Im happy,, but pissed and kicking myself for wasting mine and your time... Link to comment Share on other sites More sharing options...
Nic Posted October 9, 2009 Share Posted October 9, 2009 I was actually opting for a ebay kit.. Lol.. There no good?.. You get what you pay for, the ebay ones use cheap cores and aren't very well designed. Link to comment Share on other sites More sharing options...
