tails Posted October 8, 2009 Share Posted October 8, 2009 hey guys need a bit of help, my gearbox has recently started getting stuck in gears or when im changing coming out of one gear then not going into another?? but it does not do it all the time just every here and there it will do it? so far ive changed the clutch master cylinder but to no avail and now theres a small knocking noise from it? does anyone have an idea on what it could be?? Link to comment Share on other sites More sharing options...
tooquicktostop Posted October 8, 2009 Share Posted October 8, 2009 The clutch itself could be on the way out, does it slip Link to comment Share on other sites More sharing options...
tails Posted October 8, 2009 Author Share Posted October 8, 2009 hey i dont think its the clutch as it was only installed recently and theres no slipping Link to comment Share on other sites More sharing options...
T2 MSW Posted October 8, 2009 Share Posted October 8, 2009 Has the box got fluid in it?? Link to comment Share on other sites More sharing options...
tails Posted October 8, 2009 Author Share Posted October 8, 2009 should do only installed it a couple of months ago, i can check tomorrow though? im wondering if its anything inside the box like the selector or bualk rings? or even clucth allignment? Link to comment Share on other sites More sharing options...
T2 MSW Posted October 8, 2009 Share Posted October 8, 2009 Check you fluid level first off as its the most likely cause Link to comment Share on other sites More sharing options...
tails Posted October 8, 2009 Author Share Posted October 8, 2009 ok will try that im guessing try jack the car level undo the bolt by the reverse pivot thing? Link to comment Share on other sites More sharing options...
