AlexJames Posted October 8, 2009 Share Posted October 8, 2009 oil cooler for the pas fluid... that fan is standard. comes mainly on a lot of tts. but they get that corroded most take them off as they dont work now anyway! I thought they were the A/C pipes? Quote Link to comment Share on other sites More sharing options...
L33 Posted October 8, 2009 Share Posted October 8, 2009 all mine were removed, so was the fan to fit the FMIC Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 8, 2009 Share Posted October 8, 2009 It looks simply like the part of the radiator the draws air into it when stationary. the Viscous fan on the other side blows air over the engine. I'm I missing something here?! LOL the viscous fan draws air through the radiator to help cool it, its not there to blow air over the engine My uk spec didnt have any cooling fans infront of the rad but guess it could be differant for a j spec. Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 8, 2009 Share Posted October 8, 2009 My J-Spec didn't have one, follow the power to the loom, you'll see if it's aftermarket or has been there from new where it's attached to the loom probably, Quote Link to comment Share on other sites More sharing options...
Miguel Posted October 8, 2009 Share Posted October 8, 2009 My J-Spec had it, as did nearly every stock Supra I worked on. It's the air-con rad cooler fan and is temperature activated. Part number in case anyone is interested: 88590-14090 Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 8, 2009 Author Share Posted October 8, 2009 How do people find their aircon without it.....still nice and cold? Quote Link to comment Share on other sites More sharing options...
jevansio Posted October 8, 2009 Share Posted October 8, 2009 My car never had one & my A/C was icy cold (until I ripped it out) Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 8, 2009 Share Posted October 8, 2009 Mines fine and never had that fan, pic of front of my car minus the bumper and fmic Quote Link to comment Share on other sites More sharing options...
Gambit Posted October 8, 2009 Share Posted October 8, 2009 (edited) How did this get to the bottom of page 2 before a realistic answer??? It's your air con fan, in hot conditions it kicks in. If your gas level is low it won't cut in at all. http://img94.imageshack.us/img94/6456/image1ex.jpg Edited October 8, 2009 by Gambit (see edit history) Quote Link to comment Share on other sites More sharing options...
Dave Posted October 8, 2009 Share Posted October 8, 2009 i havent got one of them Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 8, 2009 Share Posted October 8, 2009 You don't need one in Wales, just an umbrella and wellies. Quote Link to comment Share on other sites More sharing options...
Gambit Posted October 8, 2009 Share Posted October 8, 2009 You don't need one in Wales, just an umbrella and wellies. lol. If in doubt take your vin plate number to mr T and ask. Quote Link to comment Share on other sites More sharing options...
movistar Posted October 8, 2009 Share Posted October 8, 2009 How did this get to the bottom of page 2 before a realistic answer??? It's your air con fan, in hot conditions it kicks in. If your gas level is low it won't cut in at all. http://img94.imageshack.us/img94/6456/image1ex.jpg a/c will work without it but when you come to a stop you will notice that the temp a/c wont be as cold. Air flow through the a/c rad is doing the same job whilst on the move. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 8, 2009 Share Posted October 8, 2009 It also helps airflow through the water rad, as the heat from the condenser lowers the water rads efficiency when slow moving or stopped. More for very hot climates than good old Blighty. Quote Link to comment Share on other sites More sharing options...
leelbuk Posted October 8, 2009 Share Posted October 8, 2009 Had it on mine so when me and edge fitted the FMIC I replaced it with a slimline electric fan for completeness. Might have been a waste of 30 quid as I've yet to see it come on. My air con is no different than before Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 8, 2009 Author Share Posted October 8, 2009 are you aircon pipes still there with a FMIC? Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted October 8, 2009 Share Posted October 8, 2009 Yes my aircon pipes are there on both cars on my coupe with HKS R they are there , on my targa with a HDI Hybrid intercooler they are there just bent a bit but not much Quote Link to comment Share on other sites More sharing options...
Miguel Posted October 8, 2009 Share Posted October 8, 2009 The pipes you see through the front are not A/C. They are P/S and they are usualy replaced with a smaller set supplied with the front mount I/C, although some manage to mod the stock to fit Quote Link to comment Share on other sites More sharing options...
jackso11 Posted October 8, 2009 Author Share Posted October 8, 2009 is there a way to de-gas the aircon and get those pipes off? I want to get all the rust off Quote Link to comment Share on other sites More sharing options...
Homer Posted October 8, 2009 Share Posted October 8, 2009 This is the first time I have seen another supra with one of those fans in front of the radiator. The Punisher has one of these on his one it's always made me wonder why it's there as I'd never seen one on another Supra. The rad and every other part in the engine bay was stock GZ aerotop spec, the fan looked like it was there from day one and like your one is very rusty! I'd assumed it was due to the rad being from a different Toyota model, but it is the rare "thick" Supra rad and looks like it's been there from the start... Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted October 8, 2009 Share Posted October 8, 2009 you are probaly talking about the Powersteeing fluid cooler pipes, the one in front.... Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted October 8, 2009 Share Posted October 8, 2009 This is the first time I have seen another supra with one of those fans in front of the radiator. The Punisher has one of these on his one it's always made me wonder why it's there as I'd never seen one on another Supra. The rad and every other part in the engine bay was stock GZ aerotop spec, the fan looked like it was there from day one and like your one is very rusty! I'd assumed it was due to the rad being from a different Toyota model, but it is the rare "thick" Supra rad... mine is the normal rad atleast, and GZ 93 full option J-spec Quote Link to comment Share on other sites More sharing options...
movistar Posted October 8, 2009 Share Posted October 8, 2009 is there a way to de-gas the aircon and get those pipes off? I want to get all the rust off fella they are your power steering cooling pipes not air con. Clamp off at the rubber pipes that connect onto it and hey pesto you can remove to clean. Quote Link to comment Share on other sites More sharing options...
Homer Posted October 8, 2009 Share Posted October 8, 2009 mine is the normal rad atleast, and GZ 93 full option J-spec That's kind of my point, they are not normally present, this is only the 2nd time I've seen one of these on a supra. I know your car as I did an inspection of it for the previous owner shortly after she bought it Quote Link to comment Share on other sites More sharing options...
Guest SupraGTE Posted October 8, 2009 Share Posted October 8, 2009 That's kind of my point, they are not normally present, this is only the 2nd time I've seen one of these on a supra. I know your car as I did an inspection of it for the previous owner shortly after she bought it aaah JO ?? but that car does not have it ... my black aero top GZ has , the chameleon is in 10000pcs to clean up all mess, what did you think about the car when u inspected it?.... be fair as i can take critic Quote Link to comment Share on other sites More sharing options...
