fitting an FSE Sytec adjustable Fuel Regulator
a98pmalcolm
hi all.
Ok i have one spare knocking around that came off my corrado G60
and i ordered the correct parts from FSE today to it it onto my supra.
i beleive that the orignal fuel regulator is above the 1st injector.
but any advice on fitting and were all the hoses go on the regulator? I have numbered each hose do were i think the lines go. If im wrong can you tell me what is correct?
What pressure should i run it at with a BPU. I ran 4 Bar on the corrado.
I think this is the origanal relator.
http://img11.imageshack.us/img11/7962/06102009010o.jpg
And this is the sytec valve with the way i think the lines go in:
http://img62.imageshack.us/img62/961/sytec.jpg
Thanks
Paul
If you fueling is OK then there is no need to add complication.
I am assuming you have no way of controlling the fueling so by increasing the fuel pressure on a stock setup all you are doing is adding more fuel and making it richer, they run rich anyway.
The stock reg is more than upto the job and if it isnt broken dont try and fix it ;)
i cant see it being all that bad fitting one. especialy as JPS said they are great on BPU supras... well i already ordered the part for the fuel rail so i mite aswell fit it....i'll late ya all know how i get on..just wanted to check all the correct pipes were goin on the rite areas.
Thanks
Paul
I would rather fit a device that gave me a good kick in the knackers every time the odometer rolled over for another mile than one of those pieces of crap.
A few years ago I datalogged the output from one and posted it up. I'm sure if you do a search you'll soon find it. I think the results are fairly conclusive.
By all means fit an FPR if you want to, it won't be of any real benefit, but fitting an FSE will in all likelihood make your car run worse.
