Guest billywhizz007 Posted October 5, 2009 Share Posted October 5, 2009 Hi all, The end of my far left edge chrome panel has come loose and is rattling against the underside of the bonnet. Could someone please recommend a good adhesive? I guess that area won't get too hot as it's outside the engine bay. The dried stuff sticking the rest down is black in colour, don't know if that was the original colour! Thanks Link to comment Share on other sites More sharing options...
leonardjon Posted October 5, 2009 Share Posted October 5, 2009 I have the same chrome bits and my left one flaps too! I tried a few different glues but they all failed after a while - interested to know what recommendations there are! Link to comment Share on other sites More sharing options...
Guest beathacker Posted October 5, 2009 Share Posted October 5, 2009 Dont know if youve got Sikaflex glue in uk thats what i use for sideskirts and alot of other stuff should work Link to comment Share on other sites More sharing options...
Nic Posted October 5, 2009 Share Posted October 5, 2009 The panel on the top of the inner wing? I'd just either remove it or re-stick with double sided foam tape. Link to comment Share on other sites More sharing options...
Guest billywhizz007 Posted October 6, 2009 Share Posted October 6, 2009 Thanks guys, think I'll try bonding it and if it doesn't work then foam tape it is Link to comment Share on other sites More sharing options...
Terminator Posted October 6, 2009 Share Posted October 6, 2009 What ever you use make sure you degrease the area very well. Link to comment Share on other sites More sharing options...
chrispot Posted October 6, 2009 Share Posted October 6, 2009 try a good natural cure clear silicone, sticks very well to smooth surfaces, same as used in bathrooms, work well on my car, I used it to stick a thin stainless sheet over my PAS tank last year, still ok, regards chris. Link to comment Share on other sites More sharing options...
Guest billywhizz007 Posted October 6, 2009 Share Posted October 6, 2009 Thanks for the advice Phil. Thank you too Chris I will try that possibly Link to comment Share on other sites More sharing options...
