DaveSupTT Posted October 5, 2009 Share Posted October 5, 2009 Hi, I was wondering if someone could tell me what the score is with emmssions test on the Supra. Am I correct in thinking that some of the imports are exempt from the test, and hense do not require cats? My car is having its MOT today, and it has both cats removed. Its just had a complete engine rebuild so this should help with emmissions as everything is new! My car is a J-spec 1994 import. Can anyone shed any light on this. Ive tried to search for info on the web and internet but cant find anything. Cheers Dave Quote Link to comment Share on other sites More sharing options...
Matt H Posted October 5, 2009 Share Posted October 5, 2009 I doubt it... Why would they be? Quote Link to comment Share on other sites More sharing options...
DaveSupTT Posted October 5, 2009 Author Share Posted October 5, 2009 I dont know, I thought that some imports were. Thats what I was told by a garage when I had my MR2? Quote Link to comment Share on other sites More sharing options...
AlanM Posted October 5, 2009 Share Posted October 5, 2009 1992 and prior are exempt as far as I know. 1993 onwards are not Quote Link to comment Share on other sites More sharing options...
Multics Posted October 5, 2009 Share Posted October 5, 2009 My car is a 1994 R33 Skyline with an RB25DET engine. There's no cat, straight through exhaust from the turbo. On the V5 it says Import and there's no emission readings. This is what I've been told by an MOT tester: Because it's an import and the engine is not listed in the computer, the emissions are tested against the highest allowed: CO HC My engine emissions results: CO HC So that's a Pass Quote Link to comment Share on other sites More sharing options...
Scott Posted October 5, 2009 Share Posted October 5, 2009 Late 1992 onwards require a CAT test if they are UK cars. Late 1995 onwards require a CAT test regardless of whether they are UK or not. Imports are covered up to 1995, there is no reglatory test for imports up to that year. Its been covered so many times on here i struggle to see how the regulars have missed it HTH Quote Link to comment Share on other sites More sharing options...
Scott Posted October 5, 2009 Share Posted October 5, 2009 My car is a 1994 R33 Skyline with an RB25DET engine. There's no cat, straight through exhaust from the turbo. On the V5 it says Import and there's no emission readings. This is what I've been told by an MOT tester: Because it's an import and the engine is not listed in the computer, the emissions are tested against the highest allowed: CO HC My engine emissions results: CO HC So that's a Pass Thats the one, they are only listed after 1995 Trust my car to be a 96 Quote Link to comment Share on other sites More sharing options...
DaveSupTT Posted October 5, 2009 Author Share Posted October 5, 2009 Late 1992 onwards require a CAT test if they are UK cars. Late 1995 onwards require a CAT test regardless of whether they are UK or not. Imports are covered up to 1995, there is no reglatory test for imports up to that year. Its been covered so many times on here i struggle to see how the regulars have missed it HTH so is what your saying is that if the car is a 1995 or older and an import it is exempt. Or, is what your saying, is the car needs to be imported before 1995? Quote Link to comment Share on other sites More sharing options...
Scott Posted October 5, 2009 Share Posted October 5, 2009 so is what your saying is that if the car is a 1995 or older and an import it is exempt. Or, is what your saying, is the car needs to be imported before 1995? 1995 and before is exempt. I'm not sure when in 1995 they started listing the cars but being a 94 you will be fine. You might need to explain this to the testers though as some of them don't realise it, i had to anyway. Quote Link to comment Share on other sites More sharing options...
heckler Posted October 5, 2009 Share Posted October 5, 2009 so is what your saying is that if the car is a 1995 or older and an import it is exempt. Or, is what your saying, is the car needs to be imported before 1995? if the car is registered upto 1995 the co2 emmisions allowed are higher (3.5%) as there put through on a non-cat test. This ONLY applies to import cars, so if the car is registered 1996 onwards, you need a CAT for the MOT Quote Link to comment Share on other sites More sharing options...
DaveSupTT Posted October 5, 2009 Author Share Posted October 5, 2009 1995 and before is exempt. I'm not sure when in 1995 they started listing the cars but being a 94 you will be fine. You might need to explain this to the testers though as some of them don't realise it, i had to anyway. Is there anything official that I can print out to back it up should they fail it. if the car is registered upto 1995 the co2 emmisions allowed are higher (3.5%) as there put through on a non-cat test. This ONLY applies to import cars, so if the car is registered 1996 onwards, you need a CAT for the MOT I shall have to check my log book then to see when the car was registered in the UK Quote Link to comment Share on other sites More sharing options...
Scott Posted October 5, 2009 Share Posted October 5, 2009 There is, i have seen a link to it on this forum before but i have to go to work so can't search for it for you. I'm pretty sure you can search for all the MOT regulations on t'interweb but unfortunately i don't know where to look. Hopefully someone will come along who does Quote Link to comment Share on other sites More sharing options...
supra dan Posted October 5, 2009 Share Posted October 5, 2009 This is what I've been told by an MOT tester: Because it's an import and the engine is not listed in the computer, the emissions are tested against the highest allowed: thats what i was told. the supra engine is on the computer so gets the normal test. my mates evo was not listed on the computer so gets the non cat test Quote Link to comment Share on other sites More sharing options...
Terminator Posted October 5, 2009 Share Posted October 5, 2009 MOT my car loves them. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted October 5, 2009 Share Posted October 5, 2009 my car always passes with the cats in (the boot) And its a uk car Quote Link to comment Share on other sites More sharing options...
DaveSupTT Posted October 5, 2009 Author Share Posted October 5, 2009 Well Good news...IT PASSED WITH FLYING COLOURS! Spoke to the MOT place and they said the car has passed with flying colours. I said thats great and asked about the emissions and how it got on etc and he said that it flew through the emissions test and the reading was very low, even though it had no Cats in the car. So thats my car officially back on the road after over 1yr 2 months!!!! Yayyyyyyyyyyyyyyy Quote Link to comment Share on other sites More sharing options...
