How do i know if my LSD works?
devan
My 1994 NA Supra has the LSD option,
But i was looking in the fusebox cover yesterday and noticed that the 'Diff Cool' fuse slot was empty, and also, i dont have any buttons or anything on the dash (dont know if there is supposed to be).
Just wandering if there is any way if i could tell if i had a functional LSD?
Is it that easy to tell if u have lsd fitted with the skid marks? Would a car with a standard diff only leave one skid mark from one tyre?
Mine seems to step out pretty easily even in the dry but the previous owner never mentioned lsd :sly:
surely the diff won't lock up at virtually 2 miles an hour by jacking the car up ? mine didn't, although i guess it depends how the lsd works, i thought the supra has many small friction plates that needed to get hot before locking) I did the burnout test in the end and that confirmed it, now i have a TT engine you can really feel it kick in.
suppose it dose depent on the the way the diff works, but thats how i tested the diff on my bmw and both wheels went the same way with a spin tho the 1 i was spinning was goin a bit faster than the other
  dr_jekyll said:
lift the back of the car and turn one wheel by hand , if its an lsd the other wheel should turn with it the same way, if the other wheel dosnt turn or if in gear goes the opposite way its not an lsd
Not sure that's true mate as when I spin one side of my LSD the other side spins the other way.
  • 1 month later...
does anyone know the answer to this??
i tried this on my car last week when it was on a ramp, if i turned one back wheel clockwise the other side turned anticlockwise.
does that mean it does or doesn't have LSD?
  cheekymonkey said:
I jack up the car and spin the rear wheel on mine and the other goes the opposite way. I definately have an LSD.
Thanks mate - yeah see mine does the same - but the previous owner never mentioned it having LSD and i dont know how else to tell !!!!!!!
