Ark Posted October 4, 2009 Share Posted October 4, 2009 ...for that bobbly thing round the rim of a metal pipe that connects to a rubber hose? You know, the thing that stops the hose popping off because a jubilee clip goes tighter round them. And what tools can be used to make such a thing? Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 4, 2009 Share Posted October 4, 2009 if your refuring to like a metal clip on the end of the hoses and have like 2 little bits sticking up then you squeeze them together with some pliers Quote Link to comment Share on other sites More sharing options...
Ark Posted October 4, 2009 Author Share Posted October 4, 2009 Nah, not spring clips...it's the lumpy bit on the end of the actual metal pipe that the spring clip lodges up against... Quote Link to comment Share on other sites More sharing options...
AndyT Posted October 4, 2009 Share Posted October 4, 2009 Think it's the lip around the actual pipe that's being described. Usually part of the casting or original fabrication. Don't know any easy way of making one up though. Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 4, 2009 Share Posted October 4, 2009 ooooh right yeah that big! i hope you got a good fabricator Quote Link to comment Share on other sites More sharing options...
Westcoaster Posted October 4, 2009 Share Posted October 4, 2009 Is it a pipe "flare" that you mean? In which case you need a pipe flare tool! Quote Link to comment Share on other sites More sharing options...
AndyT Posted October 4, 2009 Share Posted October 4, 2009 I suppose, if you're good with welding gear, you could attach a section from a slightly larger pipe. Quote Link to comment Share on other sites More sharing options...
AndyT Posted October 4, 2009 Share Posted October 4, 2009 This bit? Quote Link to comment Share on other sites More sharing options...
Westcoaster Posted October 4, 2009 Share Posted October 4, 2009 ...for that bobbly thing round the rim of a metal pipe that connects to a rubber hose? You know, the thing that stops the hose popping off because a jubilee clip goes tighter round them. And what tools can be used to make such a thing? You need one of these! Quote Link to comment Share on other sites More sharing options...
Ark Posted October 4, 2009 Author Share Posted October 4, 2009 Yes - that's it Andy! It must be possible to press a lip into a pipe. Westcoaster - that looks ever so close, but I think it's for bending brake pipes - the guide wheel of the left is concave, not convex. Quote Link to comment Share on other sites More sharing options...
Tee from China Posted October 4, 2009 Share Posted October 4, 2009 isn't the term a flange ? Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted October 4, 2009 Share Posted October 4, 2009 normal pipe with swaged ends.you need a swaging machine.basicly opening up the end of the pipe to make it slightly bigger than the rest of thed pipe. Quote Link to comment Share on other sites More sharing options...
Ark Posted October 4, 2009 Author Share Posted October 4, 2009 That's it - a swaging tool. They cost up to £15000! I think I'll give it a miss thanks! Time to come up with a new plan. Quote Link to comment Share on other sites More sharing options...
Jake Posted October 4, 2009 Share Posted October 4, 2009 http://shop.useful-tools.co.uk/hand-beading-tool-4-p.asp Quote Link to comment Share on other sites More sharing options...
Miguel Posted October 4, 2009 Share Posted October 4, 2009 You need one of these! What, a pipe bender Brendan hit it on the nail, and Jake got the tool. Quote Link to comment Share on other sites More sharing options...
bignum Posted October 4, 2009 Share Posted October 4, 2009 The easy way would be to get a welder to run a thin bead of weld around the pipe. Quote Link to comment Share on other sites More sharing options...
AndyT Posted October 4, 2009 Share Posted October 4, 2009 http://shop.useful-tools.co.uk/hand-beading-tool-4-p.asp Wow! Very smart. Gets my vote. Quote Link to comment Share on other sites More sharing options...
