foggy147 Posted October 3, 2009 Share Posted October 3, 2009 hi guys got an annoying rattle coming from the boot any ideas what it could be? Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted October 3, 2009 Share Posted October 3, 2009 Hi mate, you just need new boot rubbers, quite a common problem and i had it myself. If you open your boot you will see that there is a rubber block either side of your boot lid, and one either side on the car itself where the boot shuts. These can perish over time and stop making a tight fit when the boot is closed, so there is abit of play and thats whats making the noise. You can get them from Toyota or a few traders on here. Hope that helps mate : Goes off to find Traders Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted October 3, 2009 Share Posted October 3, 2009 Here you go mate, Paul Whiffin is a trader on here and can sort you out with a new pair. http://domain2353448.sites.fasthosts.com/index.php?option=com_virtuemart&page=shop.product_details&flypage=flypage-ask.tpl&category_id=2004&product_id=7603&Itemid=53 Quote Link to comment Share on other sites More sharing options...
foggy147 Posted October 3, 2009 Author Share Posted October 3, 2009 thank u for that if i bought them are they easy to fit if i was to do it myself? Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted October 3, 2009 Share Posted October 3, 2009 Yes mate you can do it yourself, some people have said that they found the screws on the old ones to be quite tight, but mine came out no problem, 10 minute job to swap them over. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 3, 2009 Share Posted October 3, 2009 Make sure you get new screws with them, as you may find the old ones difficult to remove. Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted October 3, 2009 Share Posted October 3, 2009 Also, its best if you post your question up in the ' Supra Chat ' area, as more people will see it Quote Link to comment Share on other sites More sharing options...
Zofix Posted October 3, 2009 Share Posted October 3, 2009 is it only the 2 lower you swap or all 4? and what is the part number for the screws? Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted October 3, 2009 Share Posted October 3, 2009 You can order just the upper or lower 2, but you may aswell swap all 4 while your doing the job, screws come with the ones i had from Nic, and the ones from Whifbitz will aswell. Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted October 3, 2009 Share Posted October 3, 2009 If that doesnt do it, check the bumper holding plastic screws underneath the rear lights. If the joint gets too dry or worn it can give you a very bad rattle, to me forever to find this one. Answer was new plastic screws and greased the two mating faces. Quote Link to comment Share on other sites More sharing options...
foggy147 Posted October 3, 2009 Author Share Posted October 3, 2009 do u mean the ones under the car at the back or in the boot? Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted October 3, 2009 Share Posted October 3, 2009 Take the rear lights out and there are screws for the rear bumper underneath. A quick way to check is to get someone to sit in the back of your car and when it rattles get them to push up on the glass of the boot, if it stops you know its the rubbers. If not then try the other option Quote Link to comment Share on other sites More sharing options...
