Bosch 044 fuel pump bhp limit?
JamieP
Yes, that's why I assume that supra engine is more powerful than BMW's. What point did you not get?
The N/A is more powerfull, by a fair margin, but the CR is comparable I think. The drop in CR for the TT would probably mean the figures would be comparable with the BMW. I'm almost positive I read that a TT without tubbys would make around 180hp with the fuelling setup correctly.
  • Replies 192
Okay lets see...
Barometric Air pressure is aprox 1bar
What effect Air density
1 temprarure
2 pressure
20 degrees Air at watersea lvl Will have a certain amount of density if you could get 1 bar of pressurised Air to the exact same temprarure it would contain dubble the oxygen.
So aslong as the intake temprarure of the n/a and the turbo engine is the the exact same you would be stuffing the engine with dubble the Air and so get 100% more power. You say that is not true. How can your turbo produce more density at the same pressure to get more then 100%?
Here you might say Well iam cooling the Air... Fair enough But if you would feed the n/a with the same temprarure you would also increase the n/a density.
So feel free to tell me how you get the Air lets say 30%more dense at the same preussure and temp. Heck you are going to be rich :)
Writing from My iphone so bare with me
I am here: http://maps.google.com/maps?ll=57.705390,11.881201
God why don't you understand? :D
A 1500HP Supra engine without Stroker kit running 3 bar of Boost would have to make 500NA HP with a rev limit of lets say 9000. There's absolutely NO chance something like this is realistic or happening in any dimension...
Just for a side note have a read on efficiency relating to combustion engines and the impact that charged air has on it...
In short More efficient = more power and charged engines are more efficient.
The TT intake temperature will most likely be higher than an N/A as the turbo will be heating the air. Granted the intercooler will drop this temperature but I don't know how much by. This is the reason the stock TTs aren't very efficient at higher boost levels, they heat the air way too much.
Anyway, as I said... I can't explain to you how it works. I can only present you with the facts.
1. Do you agree a 2JZ-GTE running 1.0bar with the stock turbos will hit around 380hp when everything is healthy?
2. Do you agree that fitting a larger and more efficient single turbo would see more than 380hp at 1.0bar with no other intake changes?
3. Do you realise that the air/fuel mix is completely different between an N/A and a forced induction setup?
You take the price ive Said it can be up to 100% more effective..... Yeah or you could read up some yourself
I am here: http://maps.google.com/maps?ll=57.735692,11.940517
You aren't listening to sense though bud.
Lets say that a GTE makes 200hp as an N/A (It's a nice round figure and it won't be THAT far off the truth).
Going by your theory in order to make 600hp the turbo will need to produce 3 times the amount of atomospheric pressure. If we take the going rate as around 1.0bar that would mean that 2.0bar of positive pressure would be required.
This would then mean that any Supra running 600+ horsepower is running 2.0bar + pressure.
In order to hit 1000hp you would need 5 times the atomospheric pressure, therefor JP and everyone in the US must be running 4bar+.
There are some nice fast Supras in Sweden, what is the most powerful one you know of still running as a 3.0L, how much power is it making and at what boost level is it making it at?
I honestly can't put it any plainer than that, it's staring you straight in the face bud.
Nice calculation yeah it would be 2000 if it had 3 bar Boost and made 500 na
375 na hp to reach 1500bhp @ 3 bar
I am here: http://maps.google.com/maps?ll=57.721123,12.011427
U kidding me right... Yeah no 600bhp tjat use stock exhaust stock intercooler pipeing stock Intercooler and everything else stock but the turbo
I am here: http://maps.google.com/maps?ll=57.790386,12.096858
no I'm not kidding. adding an intercooler to an na would give less power, throwing on an exhaust does very little.
Adding a large intercooler only aids a turbo car by allowing the VE to remain as high as possible, it cannot increase it.
You are killing your own argument here as you don't seem to understand what you are talking about. fitting a huge 1000hp exhaust, inlet manifold and intercooler would not have any major effect on an N/A. The only reason for doing so when upgrading the turbo is so that the flow can be free allowing the increase.
According to your theory you can't increase more the 100% of the stock power per 1.0 bar. in reality, according to your theory, it would actually be less as the car would be slightly more restrictive and free flowing. not taking these restrictions into account allows for the best possible scenario...again this is according to your theory.
Therefor the absolute best you could manage with the head not being ported or modified is 600hp at 2.0bar. It would actually brought less in reality due to said restraints.
How are you not seeing how ridiculous that is? There are 600hp cars running 1.3 bar on 67mm turbos fgs.
Your are mixing about yeah sure 600 bhp @ 1.3 is no problem it would make 260 as A na
I am here: http://maps.google.com/maps?ll=57.717927,12.018672
How is it doing this though? The head hasn't been touched, the intake is stock. How is it going from 180hp to 280hp?
Are you telling me that adding an intercooler and an exhaust would give an N/A an 80hp increase? Let the boys know, they'll snap your hand off mate.
