Loads of bits and bobs
Scott
Most of the things here i'm just looking for money for old rope. I'm open to offers on everything. Wanted to give you guys first shout before firing on ebay.
1st Cat
Original Facelift OEM Passenger side Spat
Original facelift indicators. A little scratched and needing a good clean but in pretty good order. Note one of the screws are missing, won't make a difference. SOLD
MR2 Mk2 Drivers Window Switch
Closed Loop Isolator (Got 2 of this type). 1 Brand new, 1 tried
Closed Loop Isolator (Got 2 of these too) 1 Brand new, 1 tried
Bung. To replace broomsticks in dump valves etc. Got 2 of these.
Orange lenses for J-Spec rears.
Protectors for the bottom of a UK bonnet scoop. Can get the exact part numbers but the foam is for under the scoop.
MR2 MK2 Passenger Switch
Set of nuts, M12x1.5. I've got 20 of these. The one not pictured i have found.
Stock Filter Snorkle just needs a clean. SOLD
Intake Manifold. A little grubby but none the worse for wear. Came off my facelift (if that makes a difference)
Throttle body. Top right sensor thing is broken so would need replaced. Also came off my facelift.
Red coupler approx 81mm. Unused.
Clamp approx 98mm. Unused
Black carpet stuff. Can't remember the exact amount but i used 2 to cover my entire boot build.
Supra embossed carbon effect fuse box cover. Couple of scuffs as can be seen in the pic. SOLD
Facelift Chrome dial rings. Never used. SOLD
Battery Tray with drain pipe
Stereo Cage
Red Rear Marker Bulbs
Tough Spigot rings. I think they are 70mm (70.1 or something), obviously the bore is 60.1 for a supra.
MR2 MK2 Headlight Popup Arms
Chrome Battery Clamp. Needs a good clean, little corrosion starting (see pic) SOLD
Dash Rings, for around the fans. SOLD
Pre-Facelift Sidelights with LED bulbs
Regular battery clamp. SOLD
Wheel Studs. Only replaced these for longer ones.
Facelift indicator/sidelight loom. SOLD
Horny Devil Badge. Likwidart Black. SOLD
Facelift stock badge. Dark Grey. SOLD
that fuse box cover is quality mate.
what pieces are the chrome rings? just the 5 for the dash or heater etc? (1st dibs pls)
Its just the 5 rings bud. As you can see in my 2nd post i have 2 stickon ones for the air vents.
Cheers mate - so the 5 main ones are the push in type are they?
can u pm me best price for them and the 2 little stick on things please ;)
1st dibs on the Chrome Battery Clamp how much are you looking for it with p&p please
Someone has already PM'd me about it bud. I'm just doing a search just now to see what they normally go for. Cheers
PM sent
Replied :)
£30 posted sound ok? I know these normally retail for £60. I'll give them a good clean and a do-over with plastix before i send them out to make them sparkly :)
Cool, but I need to find out if I am getting a facelift or prefacelift bumper this weekend. I'll let you know after the weekend if they are still available.
