T2 MSW Posted September 29, 2009 Share Posted September 29, 2009 Please can people Post their Geo settings up for 18" wheels. May have the chance to get a setup done this weekend but need the settings to take with me. Was planning on getting it down to Chris @ Gravity to get it corner weighted at some point but thats not going to happen quickly. Need some idea of setup so dont rip through the r888 in 3 seconds flat. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 29, 2009 Share Posted September 29, 2009 I can you give you mine but they are track settings, probably not the best for everyday road use though mate. Quote Link to comment Share on other sites More sharing options...
SteveR Posted September 29, 2009 Share Posted September 29, 2009 I may be very much mistaken, but I don't think wheel size will matter that much TBH Mike. It'll affect how much side wall 'squidge' you get, but other than that toe/caster/camber/etc are still the same artefacts you'll want to look at and get set-up. Don't forget that one individual's settings may work for them but not suit your driving style & needs: my car is currently set up to just understeer when pushed (stock is setup to understeer lots), but when I go back I'll have it a bit more neutral as I think I know a little more about what what I'm doing behind the wheel now. Quote Link to comment Share on other sites More sharing options...
SteveR Posted September 29, 2009 Share Posted September 29, 2009 BTW my settings are here: http://www.mkivsupra.net/vbb/showthread.php?t=157231 Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 29, 2009 Share Posted September 29, 2009 And different dampers make the tyres work differently as well, ie. heat up quicker/slower. Plus different types of tyre need different geo settings. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 29, 2009 Author Share Posted September 29, 2009 Im just after a base to work from really, can then get it correctly done at a later date when ive got more experience in the car and know what I want from it. Riight now ive not really pushed it so dont know how it handles, could not say right now if is understears is tail happy or what. Was too scared about the brakes and the rears locking but confident Martin and I sorted that out last week when we got out a massive airlock on the brakes. Quote Link to comment Share on other sites More sharing options...
SteveR Posted September 29, 2009 Share Posted September 29, 2009 I just told Chris at CG what I didn't like about its handling when I bought it, what I'd be using it for, what I would accept but what I wanted to retain (i.e. occasional track focus but MUST be road-driveable) and how I wanted to to behave, especially at and past the limits. He turnrd that into science and numbers and delivered exactly what we discussed. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 29, 2009 Author Share Posted September 29, 2009 yeah they are the bits I dont know at the minute, I know what I want to use the car for and I would want the slight understear setup as im still a novice on a track but as to what I dont like about the car at the minute I could not say. All I do know is I dont have the expected levels of grip from the rear end I know that could be a million and one things but most of the bushes have ben changed and the geo has not been done for quite a while. Quote Link to comment Share on other sites More sharing options...
Lee_e Posted September 29, 2009 Share Posted September 29, 2009 sorry to hi-jack this thread but does anybody know how much a geo check and setting etc is ? cheer Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 29, 2009 Author Share Posted September 29, 2009 sorry to hi-jack this thread but does anybody know how much a geo check and setting etc is ? cheer Depends what you class as good, For a professional corner weight and geo setup (8-9 hrs work) ive just been quoted £450 + Vat IMO the laser alightments at local tyre places are a waste of money, and the last one I had done on a hunter camera system was about £150 for the full geo setup. Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted September 29, 2009 Share Posted September 29, 2009 Rough guide...... +5 castor, zero toe @ front 1.5mm total toe in at rear IIRC camber is your choice, if running a very hard sidewall like RE050A then min camber on rear with 1/2 degree more than rear on front. Supra adds plenty as suspension tilts. If you have rock hard suspension you can run a little more camber as it wont add as much due to lack of movement. Softer sidewall you can use a little more. The castor makes a world of difference to steering response. Good luck. Supra came from factory with too little front castor for numptys who steer like they are milking a cow, making it forgiving but like's to swap ends after the first o'clock or so. I have used the above and it was great, for traction and handling. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 29, 2009 Share Posted September 29, 2009 Toyota workshop manual here if it helps. http://www.turbosupras.com/pdfs/JZA80%20TSRM/SA.pdf Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 30, 2009 Author Share Posted September 30, 2009 Rough guide...... +5 castor, zero toe @ front 1.5mm total toe in at rear IIRC camber is your choice, if running a very hard sidewall like RE050A then min camber on rear with 1/2 degree more than rear on front. Supra adds plenty as suspension tilts. If you have rock hard suspension you can run a little more camber as it wont add as much due to lack of movement. Softer sidewall you can use a little more. The castor makes a world of difference to steering response. Good luck. Supra came from factory with too little front castor for numptys who steer like they are milking a cow, making it forgiving but like's to swap ends after the first o'clock or so. I have used the above and it was great, for traction and handling. Cheers, thats going to be really useful Quote Link to comment Share on other sites More sharing options...
Thorin Posted September 30, 2009 Share Posted September 30, 2009 The "Lance Alignment" settings... http://www.mkiv.com/techarticles/lance_alignment/index.html Quote Link to comment Share on other sites More sharing options...
Kirk Posted September 30, 2009 Share Posted September 30, 2009 if you can get them in degrees and MM maybe much easier to do! been through the system today and gone through all the other stuff this machine can do! pretty impressive bit of gear Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted September 30, 2009 Author Share Posted September 30, 2009 so we good for Saturday? Quote Link to comment Share on other sites More sharing options...
Kirk Posted September 30, 2009 Share Posted September 30, 2009 I should have it sorted by tomorrow, providing someones coming in on saturday besides me. Ill shall let you know Quote Link to comment Share on other sites More sharing options...
SteveR Posted October 1, 2009 Share Posted October 1, 2009 so we good for Saturday? Are you going to Chris' this Saturday? Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 1, 2009 Share Posted October 1, 2009 nope me (providing all goes well tomorrow) ive actualy cross checked the print out from yours to the system at my works and the target figures are 99% the same Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted October 1, 2009 Author Share Posted October 1, 2009 Are you going to Chris' this Saturday? Nope, Very busy and appears he does not want the work as never bothered to phone me back. Same goes for RSE Motorsport in Wales. So Martin and I are going to *cough* copy *cough* your setup Quote Link to comment Share on other sites More sharing options...
Kopite Posted October 1, 2009 Share Posted October 1, 2009 Mine's getting done by a local place tomorrow, might have a chat with them about Ernie's settings Quote Link to comment Share on other sites More sharing options...
SteveR Posted October 2, 2009 Share Posted October 2, 2009 nope me (providing all goes well tomorrow) ive actualy cross checked the print out from yours to the system at my works and the target figures are 99% the same Ah right, where do you work then Martin? Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted October 2, 2009 Share Posted October 2, 2009 Mine's getting done by a local place tomorrow, might have a chat with them about Ernie's settings Based on trial and error they came around. Dimitri's brother Dionosis (class 2 int race licence holder) uses them and loves the settings. Quote Link to comment Share on other sites More sharing options...
Kopite Posted October 2, 2009 Share Posted October 2, 2009 Had mine done, got a problem with 2 seized bolts so it's only semi done, had gone way out previously tho'! Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 2, 2009 Share Posted October 2, 2009 (edited) Ah right, where do you work then Martin? http://sapphiregarage.co.uk/ i do a large variety of things. From electrical, mechanical, wheels and tyres to balancing, geometry, trimming and a bit of painting Im still learning mind you but i have ambitions for the future Edited October 2, 2009 by Kirk (see edit history) Quote Link to comment Share on other sites More sharing options...
