chazuk Posted August 9, 2014 Share Posted August 9, 2014 i assume here: http://www.nengun.com/do-luck/rear-tension-set - 600$ http://www.rhdjapan.com/do-luck-rear-tension-cage-tension-bar-set-steel.html - 60,000 yen £351 Ali bit more, but not much Thats cheap both from good companys aswell.I have bought big items from nengun before and never been hit with import charges do these fit in aero top ? Quote Link to comment Share on other sites More sharing options...
Ric Posted August 9, 2014 Share Posted August 9, 2014 Theres a few models for the supra, perhaps one of them is, doesent seem to mention though, just 3 part numbers, you'd have to ask. Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 9, 2014 Author Share Posted August 9, 2014 Todays update I did some more in the rear I sorted the fuel relay and also made a cover for the tank cover as I had to cut it to new -6 feed line. To make the cover I cut out an old door skin I had and then hammed to the Shap I needed then welded it to the cover. Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 9, 2014 Author Share Posted August 9, 2014 Quote Link to comment Share on other sites More sharing options...
JackyBoi Posted August 10, 2014 Share Posted August 10, 2014 Awesome build Quote Link to comment Share on other sites More sharing options...
supersizejim Posted August 10, 2014 Share Posted August 10, 2014 Cars comming on well.. Keep up the good work mate! Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 10, 2014 Author Share Posted August 10, 2014 Cheers guys well today I managed to get the boot all back together and how it should look glad that jobs out the way pretty muck done on the inside now engine and Box to be started again. Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 18, 2014 Share Posted August 18, 2014 Updates? Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 18, 2014 Author Share Posted August 18, 2014 Small update I managed to find a proper low fuel waring light so fitted that and the warning light Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 19, 2014 Author Share Posted August 19, 2014 Not got much done tonight got bumper and bonnet off and removed my old 3 inch intercooler in one of Paul's 4" ones so mocked that up. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 20, 2014 Share Posted August 20, 2014 Looking good mate Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 20, 2014 Author Share Posted August 20, 2014 Looking good mate Cheers mate i finally get to use that loom I got off you lol. Your cars coming on leaps and bounds to loving the work. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 20, 2014 Share Posted August 20, 2014 Cheers mate i finally get to use that loom I got off you lol. Your cars coming on leaps and bounds to loving the work. Ha wow, thats been a while Cheers dude Quote Link to comment Share on other sites More sharing options...
chazuk Posted August 20, 2014 Share Posted August 20, 2014 looking good mate , have you done away with the fuel pump ecu ? where does that big block connector go to now ? Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 20, 2014 Author Share Posted August 20, 2014 looking good mate , have you done away with the fuel pump ecu ? where does that big block connector go to now ? Yep that's in the bin lol which connector mate? Well not done much tonight just a bit more practice on aluminium tig welding pretty much got the hang of it Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 20, 2014 Share Posted August 20, 2014 Skills! I never did ask what kinda power will it be running? Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 20, 2014 Author Share Posted August 20, 2014 Only low mate around 530 ish will see what it makes at 1.6 bar. Only running a small turbo Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 21, 2014 Author Share Posted August 21, 2014 Ok got the engine back out its hole to start work on. I began with swaping the manifolds over for my zirotec coated one and fitted my trd engine mounts, Also had a delivery :-) Quote Link to comment Share on other sites More sharing options...
Luxluc Posted August 22, 2014 Share Posted August 22, 2014 Wow. Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 25, 2014 Author Share Posted August 25, 2014 Managed to get the other engine mount on and fit the oil pressure and knock sencors for the syvecs, also removed the oil cooler and cleaned it. Also started to mock up my fuel rail set up I had brought a kit off srd with 1000cc asnu injectors and rail. But I also brought a phb r rail which Is a bit nicer but was designed to mount to there intake, so I had to drill and tap it To fit the stock rail, missing a few bits so could not fit 100%. But will be getting them in the week, Quote Link to comment Share on other sites More sharing options...
Kaan W Posted August 25, 2014 Share Posted August 25, 2014 Looking good Matt Quote Link to comment Share on other sites More sharing options...
supra matt Posted August 28, 2014 Author Share Posted August 28, 2014 Cheers mate well after getting a quote for a new air con condenser from Paul for well over £200 I got one off eBay USA for £109 delivered and import payed it's a denso one to and It only took a week to get here also Lee P sent me My misses bits (big thanks) which is cool as can finish fuel rail now. Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 29, 2014 Share Posted August 29, 2014 Coming along nicely Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 29, 2014 Share Posted August 29, 2014 Keep up the good work. I was worried about removing the mirror from the housing the other day.........your tapping your rail. Quote Link to comment Share on other sites More sharing options...
supra matt Posted September 21, 2014 Author Share Posted September 21, 2014 Well been doing 70 hour weeks at work to get a job finished so not had much time for this but I've been on it this weekend and got a fue bits done. Like sorted fuel rail and injectors, painted oil dip stick, Powder coated one of my cam covers, Soda blasted my gear box and cam cover to clean them up. Also fitted up new aircon rad and dryer, Also done few other bits his come pis enjoy, Quote Link to comment Share on other sites More sharing options...
