Blackie Posted November 21, 2011 Share Posted November 21, 2011 That dash looks fantastic Link to comment Share on other sites More sharing options...
supra matt Posted September 25, 2012 Author Share Posted September 25, 2012 Cant belive i have not done anything to this in so long but time for an update as i finally have some time back to myself its time to get this finished (I HOPE lol) well tonight i stated on my engine i have a uk spec i brought as it had just had a brand new water and oil pump fitted, I will be ditching the uk head in favour for a j-spec i have with hks 264 cams , im not building the engine just going to refresh it with new piston rings , big ends and arp head bolts as only looking for around 570 to 600 bhp. his some pics of the engine i started tearing it down . Link to comment Share on other sites More sharing options...
ManwithSupra Posted September 25, 2012 Share Posted September 25, 2012 Subscribed PS. Did you get my PM Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted September 26, 2012 Share Posted September 26, 2012 Best/fun part of building a supra imo, i loved building my engine from the bottom up with new parts. best of luck Matt Nice realistic power aim you have set yourself too Link to comment Share on other sites More sharing options...
supra matt Posted November 1, 2012 Author Share Posted November 1, 2012 well small update again not done much as been busy , i've now removed the sump and cleaned the block face and piston tops using 3m roloc bristle brush also checked the crank thrust clearance which was with the book figures , next job is pistons out and new rings. Link to comment Share on other sites More sharing options...
supra matt Posted November 5, 2012 Author Share Posted November 5, 2012 (edited) - - - Updated - - - got some more done took the pistons out to deglaze the bores and fit new rings and bearings while i was at it i checked all the bores to make sure they were still with in the book figures. Also cleaned the pistons his the pics , Edited November 5, 2012 by supra matt (see edit history) Link to comment Share on other sites More sharing options...
supra matt Posted November 5, 2012 Author Share Posted November 5, 2012 (edited) enjoy Edited November 5, 2012 by supra matt (see edit history) Link to comment Share on other sites More sharing options...
supra matt Posted November 12, 2012 Author Share Posted November 12, 2012 (edited) got a bit more done to this piston rings and shells now in used ARP rod bolts and sump going back on , Edited November 12, 2012 by supra matt (see edit history) Link to comment Share on other sites More sharing options...
supra matt Posted November 12, 2012 Author Share Posted November 12, 2012 Link to comment Share on other sites More sharing options...
teddan Posted November 12, 2012 Share Posted November 12, 2012 looks great, but the seal should be a little different for the upper oil pan? the seal should be on the outside instead of inside for some holes if I don't remember wrong... Link to comment Share on other sites More sharing options...
supra matt Posted November 12, 2012 Author Share Posted November 12, 2012 thanks for the reply mate ill double cheek and redo , if needs be Link to comment Share on other sites More sharing options...
listy Posted November 12, 2012 Share Posted November 12, 2012 When I did mine I went completely round every hole. No problems for me so far. If the seal is inside the stud holes, can't see there being a problem. You surely would only have a problem if the seal was outside the stud holes, as that would maybe allow oil to seep down the threads. Link to comment Share on other sites More sharing options...
supra matt Posted November 12, 2012 Author Share Posted November 12, 2012 When I did mine I went completely round every hole. No problems for me so far. If the seal is inside the stud holes, can't see there being a problem. You surely would only have a problem if the seal was outside the stud holes, as that would maybe allow oil to seep down the threads. Ya thats what i thought and as you can see in the pics there is a hole bead round the inside where the surfaces have been bolted together so should be no where for the oil to escape , Link to comment Share on other sites More sharing options...
teddan Posted November 13, 2012 Share Posted November 13, 2012 I think you would be fine mate but for your info Link to comment Share on other sites More sharing options...
chazuk Posted November 14, 2012 Share Posted November 14, 2012 Nice work mate Link to comment Share on other sites More sharing options...
supra matt Posted November 15, 2012 Author Share Posted November 15, 2012 cheers mate his another small update i got the arp head studs in and head back on and bolted down and hks 264 cams in. Link to comment Share on other sites More sharing options...
supra matt Posted December 6, 2012 Author Share Posted December 6, 2012 right got a bit more done and brought myself a new toy to make life easer to work on the car , his the pics of what ive been upto. Link to comment Share on other sites More sharing options...
Jamesy Posted December 6, 2012 Share Posted December 6, 2012 Nice work dude liking the ramp Link to comment Share on other sites More sharing options...
Supra Gaz Posted December 6, 2012 Share Posted December 6, 2012 Awesome dude, are your headlights tinted? Link to comment Share on other sites More sharing options...
supra matt Posted December 6, 2012 Author Share Posted December 6, 2012 Nice work dude liking the ramp cheers mate Awesome dude, are your headlights tinted? thanks mate yes i give them a little tint Link to comment Share on other sites More sharing options...
350bhp Posted December 6, 2012 Share Posted December 6, 2012 i have just read this whole thread your project and build is excellent top work, everything from strip down to rebuilding inside and outside of car , rebuilding engine , spraying car and rebuilding interior and custom dash and controls everything is just awesome one of the best Link to comment Share on other sites More sharing options...
supra matt Posted December 6, 2012 Author Share Posted December 6, 2012 Are thanks for taking the time to read it mate and thanks for the great feed back mate Link to comment Share on other sites More sharing options...
hodge Posted December 6, 2012 Share Posted December 6, 2012 That's 1 damn awesome ramp you've got there Matt, the top water elbow is pretty tasty too Top work as usual. I'd kill for a garage/workshop like that. Link to comment Share on other sites More sharing options...
supra matt Posted December 6, 2012 Author Share Posted December 6, 2012 cheers mate you should get one for your garage and many thanks for the water neck mate looks good on . Link to comment Share on other sites More sharing options...
Parry_10 Posted December 6, 2012 Share Posted December 6, 2012 Nice to see you working on your own car for a change:D Will have to pop down when its up and running mate. Link to comment Share on other sites More sharing options...
