Creaky Chipboard Landing Floor
Rob
Soon we will have to replace our stair carpet again, now our last doggie has sadly departed us, and therefore I have an opportunity to resolve the creaky floor, which creaks like a motherlover.
About 5 years ago when we moved in I had all the carpets replaced and back then I used 100's of chipboard screws to try and resolve the problem throughout the upstairs rooms but they had no effect. We tried the "talc in the joints" method too.
Any other ideas this time around?
I have heard that sheradized ring shank nails will prevent movement. All the pipe work is roughly shown by pencil marks so that should be safe.
The commonest cause of creaking is fretting of the chipboard on the nails themselves. If you can bear the time and effort pull all the nails and re-secure with exterior grade decking screws. There are some superb ones we use for fencing that have a square hole in the head, and come with a really high quality square ended drill driven driver in a pack of 250 screws. They are FAR less likely to slip and round out than Phillips or similar headed ones. The boards do not sit flat on all the joists, so if you leave some nails in sod's law states they will be where the board flexes, and creaks up and down the nail. The boards are powerful enough in warp to pull even aggressively ringed annular ring nails loose.
This is something we are forever putting right for customers, we just pull the floor up then glue and screw it to the joist, never a creek or squeek to be heard again.
problem i had with my old barrett house is the boards were put down before the partitions walls so you couldnt take them up :(
