electric power steering pump
barneybrendan
It's nothing like as easy as it may sound, most have ecu control of the pump and rack valving, and use a steering rack designed to use a (relatively) low pressure, low flow electric pump. You would need a VERY good reason to try and run electric power steering on something as heavy as a MKIV anyway, most are for light cars, often mid engined. Why can't you use a stock hydraulic pump?
its in my way where it is at the moment,rather than remounting it by the alternator thought of electric instead
Even if you have to mount it driven by a quill shaft in the passenger footwell it'll be easier with less potential issues than trying to run a rack designed to use a fairly big engine driven hydraulic pump off an electrically driven one. You'll need the flow and pressure figures for the stock pump to check if an electric one will have enough oomph. Not sure if these are available anywhere, I'll have a look in the manuals tomorrow if you haven't got them, and it helps?
those figures would be handy cheers,
