Ark Posted September 28, 2009 Share Posted September 28, 2009 Yeah not exactly cheap, but it is a complete kit with all fitting included specifically to fit the Supra. Mine was on my car for 7 years and no problems throughout that time, so quality is good. Seconded - they retail for around £650 I think. However, if you add up the cost of all that -10 hose, fittings, cooler, take-off plate and filter relocater, a DIY kit won't save much cash, especially when you factor in the hassle of making your own brackets and stuff. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2009 Share Posted September 28, 2009 Seconded - they retail for around £650 I think. However, if you add up the cost of all that -10 hose, fittings, cooler, take-off plate and filter relocater, a DIY kit won't save much cash, especially when you factor in the hassle of making your own brackets and stuff. Yeah forgot to mention the HKS kit also includes relocation for the oil filter. Quote Link to comment Share on other sites More sharing options...
Kirk Posted September 28, 2009 Share Posted September 28, 2009 i dont know much about that particular kit but does the filter need relocating? Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2009 Share Posted September 28, 2009 i dont know much about that particular kit but does the filter need relocating? No it doesn't *need* relocating, it just makes it a little easier to get at the oil filter come service time (not that the stock oil filter location is that difficult to access). Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 i dont know much about that particular kit but does the filter need relocating? No it doesnt. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 Garage Whifbitz 25 row oil cooler kit looks really good value bud.....whats an approx cost to get sumin like that fitted Paul? Is there any BHP gain from them or is it just to help the engine run cooler? Thanks. Fitting cost normally about £100 approx depending on mounting position and easy of mounting. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2009 Share Posted September 28, 2009 Is there any BHP gain from them or is it just to help the engine run cooler?. Zero HP gains. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 29, 2009 Author Share Posted September 29, 2009 Has anyone heard of failing thermostats? I'm thinking that could be a really bad thing and maybe a known issue with cheaper brands? Is there anything else that I should look out for when choosing/fitting the cooler? As Nic's scary story tells; when messing with the oil system, do it right the first time! Quote Link to comment Share on other sites More sharing options...
mrgee2jz Posted September 29, 2009 Share Posted September 29, 2009 Has anyone heard of failing thermostats? I'm thinking that could be a really bad thing and maybe a known issue with cheaper brands? Is there anything else that I should look out for when choosing/fitting the cooler? As Nic's scary story tells; when messing with the oil system, do it right the first time! the mocal ones have a bolted in thermostat which isnt coming out in a hurry, i thnk they should really be changed every few years or so, but thats just coming from me. car manufactures like bmw never really get changed untill the seals leak slightly Quote Link to comment Share on other sites More sharing options...
