bodilx6 Posted September 28, 2009 Share Posted September 28, 2009 I need an oilcooler for my bpu 93 manual j-spec as I keep running hot when doing 120+ on the autobahn or ½ way around the Ring, that I visit a couple of times a year. I value reliablilty the highest (MUST not suddenly leak, there for fittings and connection points must be top qual). Then fitting and looks/brand the lowest. It must be controlled by a thermostat as my car is a DD in the city so oil temp must rise quickly. Also, I'm currently running a Greddy oil temp gauge and must in some way be able to fit my sensor, perferably in the sadwichplate (where it is now) but I'n not sure how this is possible with a plate with oil cooler fittings. Currently I'm using this: Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 I sell a variety of different sizes, you can see the details here http://www.garagewhifbitz.co.uk/index.php?option=com_virtuemart&page=shop.browse&category_id=2317&Itemid=53 Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 28, 2009 Author Share Posted September 28, 2009 Looks good. Will the small 16 row be enough to keep my cool for quick autobahn stints? (now, it runs 130c+ after 5 min of 130mph+) I don't do long track sessions. Mainly just a single lap of the ring as a max, so it should just keep the oil at optimum temp for 10 minutes at a time or so. With fittings, are they direct fit into the engine bay of the jza80, battery side or do I need to drill/fabricate anything? Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 Looks good. Will the small 16 row be enough to keep my cool for quick autobahn stints? (now, it runs 130c+ after 5 min of 130mph+) I don't do long track sessions. Mainly just a single lap of the ring as a max, so it should just keep the oil at optimum temp for 10 minutes at a time or so. With fittings, are they direct fit into the engine bay of the jza80, battery side or do I need to drill/fabricate anything? Bigger the better in this situation normally. The kits I supply, you will need to cut the hose to length and make brackets for mounting the coolers, very easy for anyone with a garage. Ta Quote Link to comment Share on other sites More sharing options...
mrgee2jz Posted September 28, 2009 Share Posted September 28, 2009 I need an oilcooler for my bpu 93 manual j-spec as I keep running hot when doing 120+ on the autobahn or ½ way around the Ring, that I visit a couple of times a year. I value reliablilty the highest (MUST not suddenly leak, there for fittings and connection points must be top qual). Then fitting and looks/brand the lowest. It must be controlled by a thermostat as my car is a DD in the city so oil temp must rise quickly. Also, I'm currently running a Greddy oil temp gauge and must in some way be able to fit my sensor, perferably in the sadwichplate (where it is now) but I'n not sure how this is possible with a plate with oil cooler fittings. Currently I'm using this: Hi, i Use a mocal setup in my conversions with a 16row mocal oil cooler and a mocal thermostatically controled sandwich plate, but like you said if your running a oil temp gauge there are 2 ways of doing it, 1. using a sandwhich plate with cooler takeoffs and and a inline thermostat on the pipework. or taking the temp from the oil pressure sender ect... or 3 drill and tap the thermostatic plate and plum your sensor into that. The standard thermostatic setup normally costs me around £180 and if your running an inline thermostat will cost around £220 thats including pipes, connectors, clips. all you should need to buy is a new oil filter (recommended) You could fit a larger cooler, but it all depends on if you have space to. you could either locate it behind the passenger side bumper vent (where the indicator is) or in the middle behind your fmic if you have one if your have a large bumper and if it wont fit anywhere else. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 Hi, i Use a mocal setup in my conversions with a 16row mocal oil cooler and a mocal thermostatically controled sandwich plate, but like you said if your running a oil temp gauge there are 2 ways of doing it, 1. using a sandwhich plate with cooler takeoffs and and a inline thermostat on the pipework. or taking the temp from the oil pressure sender ect... or 3 drill and tap the thermostatic plate and plum your sensor into that. The standard thermostatic setup normally costs me around £180 and if your running an inline thermostat will cost around £220 thats including pipes, connectors, clips. all you should need to buy is a new oil filter (recommended) You could fit a larger cooler, but it all depends on if you have space to. you could either locate it behind the passenger side bumper vent (where the indicator is) or in the middle behind your fmic if you have one if your have a large bumper and if it wont fit anywhere else. They dont work properly behind the FMIC, needs to be in direct airflow. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2009 Share Posted September 28, 2009 I used the HKS R Type Oil Cooler, the kit is specifically designed to fit the JZ80 Supra in LH side bumper opening, the quality of the components is very good. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 I used the HKS R Type Oil Cooler, the kit is specifically designed to fit the JZ80 Supra in LH side bumper opening, the quality of the components is very good. ££££££ Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2009 Share Posted September 28, 2009 ££££££ Yup Quote Link to comment Share on other sites More sharing options...
Miguel Posted September 28, 2009 Share Posted September 28, 2009 Nic's true identity: Quote Link to comment Share on other sites More sharing options...
Axle Posted September 28, 2009 Share Posted September 28, 2009 ££££££ How much? Quote Link to comment Share on other sites More sharing options...
Ark Posted September 28, 2009 Share Posted September 28, 2009 I used the HKS R Type Oil Cooler, the kit is specifically designed to fit the JZ80 Supra in LH side bumper opening, the quality of the components is very good. So do/did I - worked really well, but it's not compatible with a Greddy 3-row, so I swapped in a Mocal 110 x 25 row in there. Bit of a compromise since there is less surface area, but better than nothing. Quote Link to comment Share on other sites More sharing options...
mrgee2jz Posted September 28, 2009 Share Posted September 28, 2009 They dont work properly behind the FMIC, needs to be in direct airflow. Yeh, direct airflow is alot better, but on the trial kit its slightly difficault to get it there:blink: Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 How much? Your paying for a name. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 Yeh, direct airflow is alot better, but on the trial kit its slightly difficault to get it there:blink: There's always a way. Quote Link to comment Share on other sites More sharing options...
mrgee2jz Posted September 28, 2009 Share Posted September 28, 2009 There's always a way. Well i cant knock that Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 28, 2009 Author Share Posted September 28, 2009 I used the HKS R Type Oil Cooler, the kit is specifically designed to fit the JZ80 Supra in LH side bumper opening, the quality of the components is very good. Hey Nic, good to see you here. Been some time I have also been recommended this kit from a couple of HKS-feliacs here in DK. But it is like 700£ or something. Thats quite a difference, but I like the idea of quality and fitting but not so much the price for the brand By the way, can you still supply the HIDs? I need some for my fogs that'll match the 6500k I got from you for my low beam. ... Thanks, keep em comming :-) Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 28, 2009 Share Posted September 28, 2009 i was considering one for mine! would there be somewere for it to go? behind a boost pip or sumin? http://img23.imageshack.us/img23/3294/14072009276.jpg Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2009 Share Posted September 28, 2009 I have also been recommended this kit from a couple of HKS-feliacs here in DK. But it is like 700£ or something. Thats quite a difference, but I like the idea of quality and fitting but not so much the price for the brand Yeah not exactly cheap, but it is a complete kit with all fitting included specifically to fit the Supra. Mine was on my car for 7 years and no problems throughout that time, so quality is good. By the way, can you still supply the HIDs? I need some for my fogs that'll match the 6500k I got from you for my low beam. Sorry I'm not trading at the moment, it'll be another couple of months or so until I am able to again, I'll be able to supply the same kit then if still needed. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 i was considering one for mine! would there be somewere for it to go? behind a boost pip or sumin? http://img23.imageshack.us/img23/3294/14072009276.jpg They'll be room, thats why its best to buy a kit you mount yourself rather than the off the shelf kits which bolt in a certain position. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 28, 2009 Share Posted September 28, 2009 They'll be room, thats why its best to buy a kit you mount yourself rather than the off the shelf kits which bolt in a certain position. what sort of cost is it for supplyed and fitted? Quote Link to comment Share on other sites More sharing options...
Alex Posted September 28, 2009 Share Posted September 28, 2009 a98pmalcolm - please use a spell checker and a check what you have written makes sense! I asked in another thread of yours and again here you demonstrate a complete lack of interest in posting correctly spelt words. The more effort you put into posting the more effort other members will put into replying! Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 28, 2009 Share Posted September 28, 2009 what sort of cost is it for supplyed and fitted? I sell a variety of different sizes, you can see the details here http://www.garagewhifbitz.co.uk/inde...2317&Itemid=53 Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 28, 2009 Share Posted September 28, 2009 Garage Whifbitz 25 row oil cooler kit looks really good value bud.....whats an approx cost to get sumin like that fitted Paul? Is there any BHP gain from them or is it just to help the engine run cooler? Thanks. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 28, 2009 Share Posted September 28, 2009 Word of warning to anyone fitting an oil cooler, only ever use top quality screw type fastenings and quality hose. It can go horribly wrong if you don't, as I personally found out a number of years ago. See HERE Quote Link to comment Share on other sites More sharing options...
