Leaking petrol line
Omlaysause
.........the thread below is worth a read and also the brake lines worth checking if the fuel line is leaking from this area.
http://www.mkivsupra.net/vbb/showthread.php?t=140112&page=2
Thanks Scooter.
Just done the brakes today, calipers, discs, pads.
The pipes don't look bad but this one has corroded at the same place as the rest mentioned in the thread, under the black plastric cover, where the pipes are held by the plastic holder (must be a bit of a water trap). Still not clear on how big a job it is to change?
