Omlaysause Posted September 26, 2009 Share Posted September 26, 2009 Hi, One of my petrol lines is corroded and leaking underneath the car. Any idea how big a job this is?? Link to comment Share on other sites More sharing options...
Scooter Posted September 26, 2009 Share Posted September 26, 2009 .........the thread below is worth a read and also the brake lines worth checking if the fuel line is leaking from this area. http://www.mkivsupra.net/vbb/showthread.php?t=140112&page=2 Link to comment Share on other sites More sharing options...
merckx Posted September 26, 2009 Share Posted September 26, 2009 You really need to use at least a pair of ramps, access to the pipes isn't too bad. I relaced the fuel line that goes to the filter, very reasonably priced from the parts dept at my local Toyota dealer. Link to comment Share on other sites More sharing options...
Omlaysause Posted September 26, 2009 Author Share Posted September 26, 2009 .........the thread below is worth a read and also the brake lines worth checking if the fuel line is leaking from this area. http://www.mkivsupra.net/vbb/showthread.php?t=140112&page=2 Thanks Scooter. Just done the brakes today, calipers, discs, pads. The pipes don't look bad but this one has corroded at the same place as the rest mentioned in the thread, under the black plastric cover, where the pipes are held by the plastic holder (must be a bit of a water trap). Still not clear on how big a job it is to change? Link to comment Share on other sites More sharing options...
merckx Posted September 27, 2009 Share Posted September 27, 2009 Still not clear on how big a job it is to change? Lifting the car up to give you plenty of room is the key. Use your iniative for the rest, it's only a length of pipe. Link to comment Share on other sites More sharing options...
