2nd hand UK Spec front and rear brakes
Paul Whiffin
Got a set of UK spec front and rear brakes available.
Front brakes: pads are shafted, the discs are lipped, 4 pot calipers are fine, £200 as they are or I can supply new discs and pads at an extra cost
Rear brakes, pads are like new, discs are worn but some life left in them, 2 pot calipers all ok, £350
Delivery on top if required.
Picture attached for you
Any questions just ask
Cheers
Paul
http://www.garagewhifbitz.co.uk/images/stories/gw_images/2ndhandparts/brakes.jpg
Not sure if the j-spec's and Uk's are different. The bolt you refer to is the banjo bolt (it will have a hole for the brake fluid). If the J-Spec banjo bolt is a different thread or size then you will need it, if its not then you can just use your own.
The gasket is required too, i would get new ones of those regardless.
On mine its a copper washer/gasket. It should be a washer with a little tab to hold it in place (i think thats what mine was anyway).
I don't think you would need to get one from MR-T but i would replace them with new ones that haven't been previously compressed.
If you haven't done this before i wouldn't rule out doing it yourself just yet. Its a straight forward enough job but you have to be careful with overtightening and undertightening things. Its good to have someone who knows what they are doing help you out. Know anyone local?
The calipers were easier than the brakelines for me to replace. Where the line connects onto the pipe is a bitch. I struggled with the caliper bolts though, they are on TIGHT.
