window fuses
bradleyh_15
I'd check to see if the loom that plugs into the back of the doorcard has unclipped itself. I think this needs to be plugged in for either window to work.
The drivers side connector does indeed need to be in for the passenger to work. If the drivers is out then neither will work.
You may have a fault with the drivers side.
