heyy everybody..need help asap!!
95SupraTT
i recently just became the proud owner of 1995 toyota supra twin turbo auto.. the car has 18 inch wheels with nitto nt555's on back and falkne in front.. whats a good air pressure for all of the tires?? also how do i stop the power steering squeek? it does it every once in a while.. thanks guys.. i will post pics soon..
36psi is recommended by Toyota. Many people run slightly differant though. For example 36 front and 34 rears. Have a play around with pressures between 34 and 36 and you will find out what best suits you. If you put differant pressures in the front and back you will want the lower pressure on the back. Don't however go over 36 and dont go below 34 really.
Edited by hoff (see edit history)
Power Steering noise is usually from the power steering pump, sometimes it can be the belt, but the pump is the common failure point. Often if you have to much debris go threw the system it will also cause issues with the power steering rack as well.
I did have 36 psi all round however it made the rears wear in the middle more due to over inflation. Therefore i lowered the rears to 33.
I currently run 36psi front, 33psi rear.
Yup, found exactly the same, when I ran 35/36 rear the tyres would always wear a lot more across the center 3". 36 front 33 rear.
Bob.
