luisito-awo Posted September 21, 2009 Share Posted September 21, 2009 I'm planning to swap my supra n/a engine with an atisto 2jzgte twin turbo engine now my question is can the 5spd w58 gearbox handle the 2jzgte power? And what about the ecu and wire harness and do i need to look for an 2jzgte supra ecu harness? Or can I use the n/a supra ecu and harness ?? Quote Link to comment Share on other sites More sharing options...
ilicos Posted September 21, 2009 Share Posted September 21, 2009 (edited) The gearbox can handle stock TT power and maybe slightly more but you will need TT engine loom, power steering resevoir, and Radiator fan and shrould if i remember correctly. Plenty of threads on here about it. http://www.mkivsupra.net/vbb/showthread.php?t=136136 http://www.mkivsupra.net/vbb/showthread.php?t=176732 Edited September 21, 2009 by ilicos (see edit history) Quote Link to comment Share on other sites More sharing options...
supspower Posted September 21, 2009 Share Posted September 21, 2009 Tough question............ Quote Link to comment Share on other sites More sharing options...
ilicos Posted September 21, 2009 Share Posted September 21, 2009 I assume my first post disappeared:search: Quote Link to comment Share on other sites More sharing options...
miko_supra Posted September 21, 2009 Share Posted September 21, 2009 The w58 can handle up to BPU level, most people haven't had any issues but i know a few have broken at around 400bhp. You will need an uprated clutch too. And yes you need a 2jz-GTE ecu, loom, and a tt instrument dial cluster. Quote Link to comment Share on other sites More sharing options...
luisito-awo Posted September 21, 2009 Author Share Posted September 21, 2009 The gearbox can handle stock TT power and maybe slightly more but you will need TT engine loom, power steering resevoir, and Radiator fan and shrould if i remember correctly. Plenty of threads on here about it. http://www.mkivsupra.net/vbb/showthread.php?t=136136 http://www.mkivsupra.net/vbb/showthread.php?t=176732 Now can I use the power steering , radiator , engine loom and ecu & harness ect ect from the aristo ? Or must it be from a tt supra Quote Link to comment Share on other sites More sharing options...
