Steve Posted April 29, 2005 Share Posted April 29, 2005 Am looking to upgrade the injectors to 650cc. Which would be the better fuel controller to usew SAFC or Emanage? What else would i need with the emanage or SAFC? Need to allow for future mods aswell. Thanks Quote Link to comment Share on other sites More sharing options...
Alex Posted April 29, 2005 Share Posted April 29, 2005 Ideal list IMO: eManage + AEM Wideband sensor and gauge + Field harness Mohd of mohdparts.com will supply a modified field harness already prepped to accept an eManage Quote Link to comment Share on other sites More sharing options...
Steve Posted April 29, 2005 Author Share Posted April 29, 2005 Is the AEM sensor and gauge a must or just advisory? I presume the field harness allows it to connect to the supe? Quote Link to comment Share on other sites More sharing options...
Jake Posted April 29, 2005 Share Posted April 29, 2005 I presume the field harness allows it to connect to the supe? A Fields harness is just an extension to the original ECU harness. It enables you to connect up you e-Manage (and whatever else you like) outside of the car in your own workshop or wherever. You then unplug the stock harness from the ECU and plug the Fields harness in between the two. They're great for convienience but not cheap. They're a 'nice to have' thing. Quote Link to comment Share on other sites More sharing options...
Alex Posted April 29, 2005 Share Posted April 29, 2005 The aem Wideband is required if YOU intend to map the car, and want to always be able to see if the AFR's are safe. If you arn't interested in either, you will still need an Wideband sensor boss fitted to your car for the mapper to put his sensor in whilst he maps but you can then just seal that with a bolt. The Field harness extends the stock wiring loom by about a foot and allows you to hack it apart instead of the stock loom. Mohd's one comes with spliced connectors already for the eManage. Quote Link to comment Share on other sites More sharing options...
Alex Posted April 29, 2005 Share Posted April 29, 2005 They're a 'nice to have' thing. It's a billion times better than trying to solder in the footwell (I'm assured ). Can't think of anyone who has not been delighted not to have to hack about in the foot well Quote Link to comment Share on other sites More sharing options...
Steve Posted April 29, 2005 Author Share Posted April 29, 2005 Sorry for the questions. So which unit would be easier to use? SAFC or emanage Quote Link to comment Share on other sites More sharing options...
Alex Posted April 29, 2005 Share Posted April 29, 2005 The more Basic unit is the safc... However with a laptop the eManage, once you know what you're doing, is very clear with it's windows based software. If you have a laptop of access to one the eManage rules. Without...you'd be best off with a SAFC unless you buy the E-01 Boost Controller from GReddy which can operate the eManage. Quote Link to comment Share on other sites More sharing options...
dude Posted April 29, 2005 Share Posted April 29, 2005 The wideband guage makes it soooo easy !!!! Dude Quote Link to comment Share on other sites More sharing options...
Steve Posted April 29, 2005 Author Share Posted April 29, 2005 Where is the fields harness on that site. Cant find it??? Quote Link to comment Share on other sites More sharing options...
Steve Posted April 29, 2005 Author Share Posted April 29, 2005 What are costs for the wideband sensor and gauge? Fitted costs? Quote Link to comment Share on other sites More sharing options...
dude Posted April 29, 2005 Share Posted April 29, 2005 The WB guage will saver your motor ..............................if you watch it !!! Dude Quote Link to comment Share on other sites More sharing options...
Alex Posted April 29, 2005 Share Posted April 29, 2005 Well ignore what I said about Mohd doing a prepped harness...looks like he's stopped Sorry... The WB02 is about £270 from Dusty at MVP...you'd have to ask him for a more accurate quote...not sure how much it would be from Vortex?? Quote Link to comment Share on other sites More sharing options...
Steve Posted April 29, 2005 Author Share Posted April 29, 2005 Thanks for your help Alex and Dude Quote Link to comment Share on other sites More sharing options...
Jake Posted April 29, 2005 Share Posted April 29, 2005 It's a billion times better than trying to solder in the footwell (I'm assured ). Can't think of anyone who has not been delighted not to have to hack about in the foot well I think that's a slight exageration, they're only a million times better. I was just trying to point out that Fields harnesses aren't strictly necessary. You can do the job without one although I'd definitely prefer to have one. Quote Link to comment Share on other sites More sharing options...
Jake Posted April 29, 2005 Share Posted April 29, 2005 Thanks for your help Alex and Dude Pffft! Quote Link to comment Share on other sites More sharing options...
Homer Posted April 29, 2005 Share Posted April 29, 2005 How much do the Fields harneses go for? Matt H has almost convinced me to get one (RTLC + E-manage + E-01 + Boost gauge install happening soon). I've seen circa £200 a few years ago, is this still the going rate? Quote Link to comment Share on other sites More sharing options...
Steve Posted April 30, 2005 Author Share Posted April 30, 2005 Do you still need a FCD with the emanage? Also where does the wideband sensor fit? Thanks Quote Link to comment Share on other sites More sharing options...
