leonardjon Posted September 19, 2009 Share Posted September 19, 2009 Opened my engine bay to find a nice spray of coolant on the hoses and surrounding area. Seems like it has either dripped onto the belt or fan and been sprayed around - much like in this thread! http://mkivsupra.net/vbb/showthread.php?t=183144&highlight=coolant I have undone and re-fitted the top rad hose and there were no signs of leakage at all there. Also took it to Toyota and one of the guys had a quick look around with a torch and mirror and suggested it may be the water pump that's leaking When the engine is running i have looked from all angles (except under the car) and cannot see any leaks but there is clearly a very occasional splatter going on. Any ideas? Seems like problems are like buses, coming in twos =/ Link to comment Share on other sites More sharing options...
nero Posted September 21, 2009 Share Posted September 21, 2009 Is the radiator factory? if so they tend to seperate and you may need a new radiator. I usually prefer to go with aftermarket one's like Fluidyne, Koyo, etc. which are 1 piece welded together and the end tanks can not seperate. Link to comment Share on other sites More sharing options...
Havard Posted September 21, 2009 Share Posted September 21, 2009 Rad cap?? Link to comment Share on other sites More sharing options...
leonardjon Posted September 22, 2009 Author Share Posted September 22, 2009 Its an aftermarket alu rad as far as I know, no signs of leaks from the rad itself, though it is kinda hard to tell! Link to comment Share on other sites More sharing options...
n boost Posted September 22, 2009 Share Posted September 22, 2009 Probably a slit near one of the jubliee clips and only leaking under pressure etc. Link to comment Share on other sites More sharing options...
Havard Posted September 22, 2009 Share Posted September 22, 2009 I had a small hole in one of the coolant pipes and sprayed out only on full load. Get someone to rev the engine and use a torch to see the spray if you can..!! H. Link to comment Share on other sites More sharing options...
stevie_b Posted September 22, 2009 Share Posted September 22, 2009 (edited) Maybe get a garage to do a pressure test on the cooling system. Make sure they know what they're doing though, you don't want them to pop the heater matrix. Edit: I would suggest using Havard's method first, and get it pressure tested if that doesn't work. Edited September 22, 2009 by stevie_b (see edit history) Link to comment Share on other sites More sharing options...
