dani_r Posted September 19, 2009 Share Posted September 19, 2009 I noticed the other day that my oil pressure gauge is stuck right at the top. When I turn on the ignition all the gauges do 'the dance' where they all flick up to the top and back down again, but the oil pressure one just stays at 100psi. I noticed this after a fairly spirited drive. I've had a look at the sender connections on the sandwich plate and they seem ok. Any ideas? Many Thanks Dan Link to comment Share on other sites More sharing options...
SteveC Posted September 19, 2009 Share Posted September 19, 2009 Try giving the gauge a gentle tap to see if the needle returns to where it should be. If that doesn't work, try disconnecting and then reconnecting the power to the gauge. Link to comment Share on other sites More sharing options...
Jamesy W Posted September 19, 2009 Share Posted September 19, 2009 Pro Sport gauge? I've the same problem, except mines doesn't jam, it just fluctuates between 90 and 100. I'm positve the sender is fooked. Link to comment Share on other sites More sharing options...
trinitom Posted September 19, 2009 Share Posted September 19, 2009 just order one of this prosport gauges, hope it doesn't come faulty. Link to comment Share on other sites More sharing options...
Jamesy W Posted September 19, 2009 Share Posted September 19, 2009 just order one of this prosport gauges, hope it doesn't come faulty. Mines have been in two years now, and the only problem so far is that the sensor seams to be going a little wonky now. I am however swapping all mine over now to the digital Golwshift ones, only because I have an Innovate AFR and they look similar. Link to comment Share on other sites More sharing options...
dani_r Posted September 19, 2009 Author Share Posted September 19, 2009 Pro Sport gauge? I've the same problem, except mines doesn't jam, it just fluctuates between 90 and 100. I'm positve the sender is fooked. Dammit. That's not good. Do you think it's worth me getting in touch with the company I got them from? I haven't had them long. Surely they are under warranty? Link to comment Share on other sites More sharing options...
Jamesy W Posted September 19, 2009 Share Posted September 19, 2009 Dammit. That's not good. Do you think it's worth me getting in touch with the company I got them from? I haven't had them long. Surely they are under warranty? Dunno mate, the worse case scenario is they tell you to fook off. You ain't got much to lose If it is the sensor then I'm sure hey are about £18 on Ebay. Link to comment Share on other sites More sharing options...
Chris and Alana Posted September 19, 2009 Share Posted September 19, 2009 Most senders need to be earthed well to work properly. I used a bit of wire and earthed the sandwhich plate to the car and they all work fine Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 20, 2009 Share Posted September 20, 2009 Just buy a half decent mechanical (Bourdon tube) gauge, they are faster responding, simpler and more reliable than most low end electric gauges. Even the OE market struggles with electric sender and gauge reliability, but they can't risk high pressure lines in the interior of the car. Link to comment Share on other sites More sharing options...
dani_r Posted September 20, 2009 Author Share Posted September 20, 2009 Just buy a half decent mechanical (Bourdon tube) gauge, they are faster responding, simpler and more reliable than most low end electric gauges. Even the OE market struggles with electric sender and gauge reliability, but they can't risk high pressure lines in the interior of the car. Any specific recomendations Chris? I need a boost gauge too and fancied an electric one as opposed to mechanical. I didn't fancy tryng to wind tubing through the car without getting it kinked! Link to comment Share on other sites More sharing options...
