TT Plug in programmable ECM
David Reid
Hello
I am looking for advice I have almost finished now building a TT 6 speed for track and drift work. After all the hassle of getting my RB30SC s15 up and running on standalone management. I am looking at a plug and play solution (if one exist). I want to be specific about my requirements so please find below my must have nice to have function
Must have
  • The ability to plug into a standard Auto TT harness
  • Be possible to use MAP sensor instead of MAF (Mafs now deleted)
  • Detect crank position without the need to an additional toothed wheel
  • Run the standard coils
  • Run standard UK spec 550 injectors
  • Sequential injection
  • Boost control via PWM bleed valve
  • A recognised tuner in the UK who can tune on Dyno, I dont want a purely road derived mapping session
  • Budget approx 1K
Things that would be nice
  • Traction control
  • Support wideband with closed loop fuelling control
  • EGT support with feedback (I.e increase fuelling in the event of exceeding temp limit)
  • Launch control
I llve my Solaris. Might be slightly out of your budget, although potentially you might claw the difference back with reduced mapping & dyno time. :)
Can you also access the calibration with your own laptop as this is also important to me.
How was your installation experiance did it take long to get it set up and running?
Thanks
David
It's easy with the Solaris yes (see here), but I'd expect you would need to very carefully agree who to go about this with Ryan, as he can't be responsible for anything that goes pop on your car is the map isn't 100% as he left it.
As well as the mapping areas of the ECU, it'll also datalog whatever you want, whenever you want. It's extremely well spec'd.
Mine was the first VVTi, and the previous ECU had been bodged in, but Ryan sorted it all, carried out the install and then mapped it in record time never the less. Have a look here. :thumbs:
