Which diameter exhaust?
Paul R
Hi,
Not having much in the way of response over on clubaristo with this, so thought i'd ask here :)
I'm having a new custom stainless exhaust made up for my JZS161 Toyota Aristo Vertex TT (V300).
My question is, how far (power wise) can you go with 2.5" de-cat and center section, with twin 2.5" exhaust system? I'm debating wether to go 3" straight through - But I wont take the power past 500bhp, so I'm not sure it's worth the extra cost?
Cheers,
Paul.
Hi,
Cheers,
Paul.
you should get 500hp on a 2.5" system, my car made this with HKS superdragger which has a section in it less than 2.5"
2.5 inch is more than adequate, cheaper, has better ground clearance, should be quieter and lighter. The only way to know for sure is measure the back pressure with both size systems and see if there's much of a difference. It's easy to do with a bit of fiddling about.
Cheers Chris,
Thats what I was after :) I think i'll go for 2.5" all the way through as you say. i'll never take the car past 500bhp. I'm only planning on a small single in the future..
Paul.
