Front Speaker Brackets - Pair
Matt H
  • 4 weeks later...
Didn't I buy these off you a few weeks back...?
Yes, but I've had PM's asking for them seen as though no responses were in the thread so I've made some more up from the sheet of PLY i've got.
Is this still for sale?
Are these used in the guide to fit aftermarket speakers in the ICE forum guide?
Thanks.
Same fitments as the guide but I've modified the design so it's slightly more durable.
OK cool, but if you're selling more you should know that you sent me 2 that were exactly the same, both were for the same door. You should have glued one of the circle bits on to the other side of the frame bit.
Bollocks, you're joking... :banghead:
Have you sorted it out or do you want me to send a replacement?
Ta
Matt
Nah, i sorted it mate. I managed to chisel off one of the circle parts with a screw driver, which wasn't easy as the glue you used was strong stuff, then glued it on to the other side. Not a pretty job after i was finished with it, but it doesn't have to be as its not visible.
Good stuff then bud. Aye, as long as it does the job :thumbs:
I used no more nails, really good stuff on wood. I put the glue down, join together then clamp three sides using G-Clamps. I then spead some extra glue over the joining edges and leave a day or two like that to cure.
