a98pmalcolm Posted September 17, 2009 Share Posted September 17, 2009 Toyota Supra MKIV JZA80 HKS Hiper-D Coilovers Hay all i have a set of HKS Hiper-D Coilovers to fit on any Toyota Supra MKIV JZA80 for sale. They have a Pillow ball upper mounts; 30-point adjustable damping force and they also have adjustable ride height. All the springs are intact with no cracks. Article from the HKS website: The Hiper coilover suspension kits have been engineered to be track ready suspension that is still "streetable". Dampening and rebound can be adjusted simultaneously in 30 different increments to deliver the desired shock compression and rebound stiffness. Ride height is adjusted by simply rotating the 60mm spring retainer perches around the chromed steel shock body. The dual interlocking spring retainer perches prevent spring movement and unwanted ride height changes. The included anodised aluminium upper pillow ball mounts improve traction and steering response while maintaining suspension geometry. Also certain applications offer camber adjustments on the upper pillow ball mounts. These shocks go for £1,175 new (what I found after research) I’m starting the Bid at £99, as there is a fault with the rears. I was getting a knocking sound mainly from 1 of the rears, but I think both were. The front seemed 100% fine on my car. So the rears will need sorting out (its most properly something small). There is some sort of valve at the bottom of the suspension so I don’t know if they’re serviceable via that. I hope this is what you were looking for. Any questions feel free to ask Collection isn’t a problem. Postage will be £35 On e-bay, direct link: http://cgi.ebay.co.uk/Toyota-Supra-MKIV-HKS-HIPER-D-Coilver-Suspension-JZA80_W0QQitemZ160363365215QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item255666c35f&_trksid=p3286.c0.m14 Or copy and paste the item number into e-bay search: 160363365215 Paul Link to comment Share on other sites More sharing options...
csa Posted September 18, 2009 Share Posted September 18, 2009 will you ship these to Denmark? Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 18, 2009 Author Share Posted September 18, 2009 yer mate not a problem will cost more for delivery! Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 23, 2009 Author Share Posted September 23, 2009 Bump to let anyone interested know that theres 21 hous left! Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 24, 2009 Author Share Posted September 24, 2009 50 mins left! Link to comment Share on other sites More sharing options...
