coil pack - plug clip
Fifty
Would you believe it changing the plugs and one of the wiring clips is broken- the white clip inside is trashed. I managed to get the wiring back but I would like to replace IS THIS POSSIBLEand is it easy to do.
OH hang on MrT are supposed to do them for £3+ great Ive just come from there 50 mile trip :(
ta
50 :D
if you look at the front of the plug i.e not the end where the wires go it poke a small flat bladed screwdriver (electrical) down the side of the indvidal spade connectors this will release a clip and the wire will pull out just make sure you put the wires back the right way :thumbs:
