snake Posted September 17, 2009 Share Posted September 17, 2009 I cannot refit the 2nd cat for the MOT as my decat pipe is one section.can i refit the first and second cats to my [bPU j spec] supra,and blank of the sensor hole in the first cat. Is this safe to do on a BPU supra , if not run on full boost. Quote Link to comment Share on other sites More sharing options...
ray007 Posted September 17, 2009 Share Posted September 17, 2009 i know a friendly MOT guy in London if you cant get your way around!! Quote Link to comment Share on other sites More sharing options...
snake Posted September 17, 2009 Author Share Posted September 17, 2009 cheers ray 007.I can change the cats ,just need to know if its safe to run a bpu car with both cats in for a short while. Quote Link to comment Share on other sites More sharing options...
Guest EncoreWRC Posted September 17, 2009 Share Posted September 17, 2009 failing that... I get MOT's without visiting the test centre!!! Quote Link to comment Share on other sites More sharing options...
suprasurrey Posted September 17, 2009 Share Posted September 17, 2009 I can`t see a problem running a bpu car with the cats back in, as the cats do the same job as the restrictor ring in the exhaust. If you have a boost controller I would set it to the standard boost for your car. Quote Link to comment Share on other sites More sharing options...
snake Posted September 18, 2009 Author Share Posted September 18, 2009 :thumbs:cheers Quote Link to comment Share on other sites More sharing options...
