hard pipes for air filter
Dave
Hiya Mate, Have a look on here and see if thats any good to you,
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=GREAPSP-50
Also try contacting Envyperformance.com, they dont have any pictures for the two polished pipes they do but they might be able to help.
http://envyperformance.com/index.cfm?fuseaction=category.display&category_id=27
6th and 7th item down.
Also check to see if there are any companys near you who could make one up, I had Radtec do me one for £60 ( see Pic )
  • 3 years later...
You want to change the black plastic bit so it's *ALL* metal? That won't work, you have an air filter bolted to the bodyshell, and no flex in the pipe, yet the engine is rocking on its rubber mountings. Something will have to give, and it it won't be the engine no longer rocking on its mountings. For just this same reason alloy top rad pipes with short bits of silicone connector hose are a REALLY bad idea, as the rocking engine puts big loads into the plastic top tank of the radiator.
