abs / slip control codes
Lurch
  • 1 month later...
As per A340E manual it says the following (page 54):
63
No.2 solenoid
valve
(1) Solenoid resistance of 8 or less is detected (*) times or
more when NO.2 solenoid is energized.
(2) Solenoid resistance of 100 k or more is detected (*) 8 times
or more when No.2 solenoid is not energized.
(*) If the above failure are detected less than 8 times, the ECM
memorizes the malfunction code but the O/D OFF indicator
light does not blink.
Hope this helps....
