marbleapple Posted September 14, 2009 Share Posted September 14, 2009 Hi all Taken the day off to swap my carpet from grey to black. I can't work out how to remove the seats.... I presumed there would be bolts under the seat? - do I need to get under the car? Thanks all Quote Link to comment Share on other sites More sharing options...
mawby Posted September 14, 2009 Share Posted September 14, 2009 4 bolts, one at each corner, under small plastic covers that you need to remove first. EDIT - On the inside of the car. Quote Link to comment Share on other sites More sharing options...
AlexM Posted September 14, 2009 Share Posted September 14, 2009 There are bolts on the rails, covered by plastic covers - two on the front and three on the back. You'll need to slide the seat back and forth to get easy access. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted September 14, 2009 Author Share Posted September 14, 2009 Thanks guys.... Much appreciated. Wish me luck!! Quote Link to comment Share on other sites More sharing options...
Ian R Posted September 14, 2009 Share Posted September 14, 2009 Thanks guys.... Much appreciated. Wish me luck!! Don't forget to disconnect the wires under the set for the electrics before you pull them out. Quote Link to comment Share on other sites More sharing options...
Jake Posted September 14, 2009 Share Posted September 14, 2009 4 bolts, one at each corner, under small plastic covers that you need to remove first. EDIT - On the inside of the car. Four? It's rather more than that IIRC. Ain't there several for each of the rear runners? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted September 14, 2009 Share Posted September 14, 2009 Four? It's rather more than that IIRC. Ain't there several for each of the rear runners? One at the front and 2 at the rear of each rail if I remember correctly Quote Link to comment Share on other sites More sharing options...
AlexM Posted September 14, 2009 Share Posted September 14, 2009 I'm sure marbleapple will find out soon enough, they're pretty obvious. Quote Link to comment Share on other sites More sharing options...
mawby Posted September 14, 2009 Share Posted September 14, 2009 Four? It's rather more than that IIRC. Ain't there several for each of the rear runners?I've probably got it mixed up with another Toyota then. Quote Link to comment Share on other sites More sharing options...
jevansio Posted September 14, 2009 Share Posted September 14, 2009 5 per seat, one rail has 2 at the back Quote Link to comment Share on other sites More sharing options...
marbleapple Posted September 14, 2009 Author Share Posted September 14, 2009 Ok, managed to get the front seats out... Three at the back and two at the front Next questions.... How do I remove the plastic foot pad next to the pedals and secondly how do I remove the rear seat? Quote Link to comment Share on other sites More sharing options...
mawby Posted September 14, 2009 Share Posted September 14, 2009 Look at it closely. You'll notice two circles stand out. These are actually screws. Turn them (lots) and the foot rest will eventually come out. EDIT - Disclaimer - This post is for guidance purposes only. There may be more or fewer screws. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted September 14, 2009 Author Share Posted September 14, 2009 Look at it closely. You'll notice two circles stand out. These are actually screws. Turn them (lots) and the foot rest will eventually come out. Well I'll be damned.... Cheers! Quote Link to comment Share on other sites More sharing options...
Jake Posted September 14, 2009 Share Posted September 14, 2009 how do I remove the rear seat?pull the front of the rear seat base upwards until it pops out. Once that's done the seat just pulls out. After that you can clearly see what holds in the seat back. Quote Link to comment Share on other sites More sharing options...
