Guest gone0-60mph Posted September 14, 2009 Share Posted September 14, 2009 Hello Fellas, hope some of you with more knowledge can help me out with a question I have about my supra. Basically my car when started cold revs higher till its warm about 1500rpm that fine I understand its cold BUT when it warms up it revs at about 1000rpm very steadily for about 40 seconds and then sometimes rises to 1600rpm for 5 seconds than back down?? Any ideas why that is? It has been cold the last few mornings?? Also what is the recommended engine oil for my supra? Its a standard tt manual pre face-lift j-spec!! Thanks in advance for the help! Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted September 14, 2009 Share Posted September 14, 2009 Is your AC on? regarding oil, check the FAQ on fluids. all info in there. Whats up with all the '!!!'? Quote Link to comment Share on other sites More sharing options...
Guest bennyessex Posted September 14, 2009 Share Posted September 14, 2009 Hello Fellas, hope some of you with more knowledge can help me out with a question I have about my supra. Basically my car when started cold revs higher till its warm about 1500rpm that fine I understand its cold BUT when it warms up it revs at about 1000rpm very steadily for about 40 seconds and then sometimes rises to 1600rpm for 5 seconds than back down?? Any ideas why that is? It has been cold the last few mornings?? Also what is the recommended engine oil for my supra? Its a standard tt manual pre face-lift j-spec!! Thanks in advance for the help! They all do it, all 3 of mine have done. Its to do with A/C and power etc not sure of the specifics but its normal unless all of mine have been faulty! Quote Link to comment Share on other sites More sharing options...
Guest gone0-60mph Posted September 14, 2009 Share Posted September 14, 2009 Is your AC on? regarding oil, check the FAQ on fluids. all info in there. Whats up with all the '!!!'? Ha Ha sorry bout all the !!!??? the a/c is not on when this is happening but benneyessex below said it happened with all 3 of his so this sounds good. I will check the FAQ about the oil now. Cheers They all do it, all 3 of mine have done. Its to do with A/C and power etc not sure of the specifics but its normal unless all of mine have been faulty! Thats great news. Thanks for the help Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted September 14, 2009 Share Posted September 14, 2009 my gs 300 did this before turned out to be altenator. my supra never revs like that even cold max i think i seen was 1200rpm Quote Link to comment Share on other sites More sharing options...
Guest gone0-60mph Posted September 15, 2009 Share Posted September 15, 2009 I am a syupid fooker, air con was on the whole time just had temp up! Knocked it off and it is a1 now! Thanks lads Quote Link to comment Share on other sites More sharing options...
