Guest The Boz Posted September 11, 2009 Share Posted September 11, 2009 Hi, I'm after a black NA manual somewhere in the region of £4000-4500, but could push to £5000 if a beauty turns up. Not fussed about slight wear on bodywork or loads of modifications, just needs to run spot on. Little project starter for me. I can pick up nationwide but obviously closer to home (Stockport, South Manchester) would be preferable. Thanks in advance, Leon Link to comment Share on other sites More sharing options...
DannyW Posted September 14, 2009 Share Posted September 14, 2009 Hi, I'm after a black NA manual somewhere in the region of £4000-4500, but could push to £5000 if a beauty turns up. Not fussed about slight wear on bodywork or loads of modifications, just needs to run spot on. Little project starter for me. I can pick up nationwide but obviously closer to home (Stockport, South Manchester) would be preferable. Thanks in advance, Leon Fancy one for £3250 or thereabouts? will leave you lots more to spend on your project. Runs fantastic, paintwork is a bit rough in places, will come with 6 months tax. Has new HID facelift headlights and rear lights as well. Will get pics and the full spec if you're interested? Link to comment Share on other sites More sharing options...
