ardasaliah Posted April 28, 2005 Share Posted April 28, 2005 when in P at WOT (stationary) and in 1st WOT. The symptoms are. It hesitates at around 6000 RMP like it’s hitting a rev limiter. If I slowly rev the engine its fine. Link to comment Share on other sites More sharing options...
ardasaliah Posted April 29, 2005 Author Share Posted April 29, 2005 anyone ? Link to comment Share on other sites More sharing options...
penguin Posted April 29, 2005 Share Posted April 29, 2005 um..... coilpacks??? i had same problem when second turbo came online 5000rpm+ .... Link to comment Share on other sites More sharing options...
Ian C Posted April 29, 2005 Share Posted April 29, 2005 Er, you are bouncing it off the rev limiter in neutral, while stationary?! You know that's quite nasty for the engine don't you? If there is no load on the engine it can't be boost related as you won't make any boost. An ignition/boost related problem would actually manifest more in higher gears... -Ian Link to comment Share on other sites More sharing options...
ardasaliah Posted April 29, 2005 Author Share Posted April 29, 2005 It happens when in P at WOT (stationary) and i 1st WOT. I am only revving it to see what the symptoms are. I first noticed it when pulling away in 1st at WOT. It hesitates at around 6000 RMP like it’s hitting a rev limiter. So to see what the problem was I put it in P and revved the engine up. At 6000 rpm it hesitates. If I slowly rev the engine its fine. __________________ Link to comment Share on other sites More sharing options...
ballsoutracing Posted April 30, 2005 Share Posted April 30, 2005 New plugs needed maybe Link to comment Share on other sites More sharing options...
dude Posted April 30, 2005 Share Posted April 30, 2005 good start !!! Dude Link to comment Share on other sites More sharing options...
ardasaliah Posted April 30, 2005 Author Share Posted April 30, 2005 Plugs are new- just a loose connection. sorted Link to comment Share on other sites More sharing options...
