What fuel pressure to run on t67
spiderpigcity
You can run any pressure you want, within reason.
The ECU will be mapped at that pressure so it doesn't make to much difference, but my personal preference would be to set it to the pressure that the injectors were tested at. If you set it to anything else they won't flow 780cc and you'll then be having a bit of a guess at the flow patterns etc.
From what i can find on the net on denso 75lb 780cc injectors it should be 43 psi. Can someone confirm that?
thanks
43psi is the standard pressure for off-the-shelf injectors, from what I've seen. I personally ran mine at 38psi static as that's what the stock setup ran at. If I started again I'd set 43psi, but I can't be arsed remapping the car just because of that.
-Ian
