6 spd conversion how too
dude
Make sure you have undone the 2 cooler pipes that go to the drivers side of the box (next to exhaust in this pic) and carefully lower the trans. Unclipping and plugging the wiring loom that goes to the trans
It is VERY heavy and nose heavy with the converter full of oil.
  • Replies 103
Posted Images
You have to now decide if you are going to change the loom to a 6 spd one !!!!!! A lot of work and not 100% needed imo. The auto loom will work just fine with a few small adjustments, we will be cutting most of the plugs off and joining 2 wires so the starter works and reverse lights function, the stock speed sensor plug fits straight on to the six speed sensor. The black plug is the speed sensor plug and the big grey plug is the one with the wires we need to alter. (more on this later)
Edited by dude (see edit history)
Pretty much all the same stuff except the clutch master & slave plus the trans tunnel mod.
Box, flywheel,clutch, prop and diff if you want the correct ratios.
Would take about 2-3 hrs longer than swapping a 6 spd.
Thanks alot, as long as i didnt have to hack away at the trans tunnel , Think i'll change after the TT engine goes in! :)
  • 4 weeks later...
OK you have a big hole in the tunnel, we are going to stick the new panel in with something like Sikoflex and bolt it using the handbrake and the 2 LHD handbrake mounts plus the hole you drilled at the back of the tunnel. The Sikoflex is very strong but make sure you put plenty on the panel, we want a gas tight seal.
This topic is now closed to further replies.
