Old Laptop - IBM T21
MrRalphMan
Having a clear out and found this in the spare room.
IBM T21 - 256MB.
A bit scuffed up, but is working and running Linux at the moment.
No inbuilt WiFi, but does come with a Linksys WPC54G card.
Not recognosed by the Linux distro, but forum threads seems to indicate that this is pretty simple (for a IT geek maybe) to setup.
This Lappy does have a serial port as some people need one to map their cars.
The battery is not great at holding a charge, not sure if this is due to it being in the spare room for quite a while or if it needs replacing.
It will run Win2K or WinXp ok, a little slow but not too bad.. The Wireless card is found and works fine with Windows.
I only put Linux on it to double check it and also remove my XP key.
Collection from Essex would be prefered.
