J-spec Turbos
trinitom
what you willing to pay mine have done 48000 kms and are still fitted to my car so can be seen runnin absoulutely zero smoke and the car is started up and cooled down properly and its a clean car hence my mileage would suggest, very very smooth running motor so if interested i could let you view them and then remove em and you can take em away i want to upgrade mine to either big single or uprated twin turbo's, but depends on what my turbo's are worth.
Wonder what warranty you get?
I heard
turbo dynamics or Turbo Technics are all good companies too
But to steer clear of hybrids and stay stock for reliability, not too sure where you will get stock tubbies
I recently had a conversation over PM with dude from AFR. They are working on a small budget single kit that will run with stock ECU and injectors from the off. It won't put out any massive figures power wise but the initial purchase price reflects this. I'd certainly consider it if my turbos go pop.
Later on down the line you then have the option of changing the injectors, fuel pump and ECU whereby you'll see the true effects of the capabilities of going single. Think of it as a single conversion, in installments. :D
This sounds a real good option :clap:
