Guest rx72jz Posted September 8, 2009 Share Posted September 8, 2009 that is my first post so hi to all:) Want to ask what spark plugs use in 2jz gte vvti (with gt35 turbo) I ask because stock there are two ground electrode spark plugs. (is there difference cause it have wasted spark ignition?) thanks Jerry Quote Link to comment Share on other sites More sharing options...
Thorin Posted September 8, 2009 Share Posted September 8, 2009 that is my first post so hi to all:) Want to ask what spark plugs use in 2jz gte vvti (with gt35 turbo) I ask because stock there are two ground electrode spark plugs. (is there difference cause it have wasted spark ignition?) thanks Jerry Welcome! We have a spark plug FAQ here http://www.mkivsupra.net/vbb/showthread.php?t=41927 Quote Link to comment Share on other sites More sharing options...
Guest rx72jz Posted September 11, 2009 Share Posted September 11, 2009 thank you but that is link where is about 2jz-gte spark plugs is that same for 2jz-gte VVTI? asking cause 2jz-gte VVTI have OEM strange spark plugs: with two negative electrode on each plug and wasted spark system compare to 6 coils in 2jz-gte... Quote Link to comment Share on other sites More sharing options...
Alex Posted September 11, 2009 Share Posted September 11, 2009 Same plugs are fine. Wasted spark doesn't need different plugs. Multi electrode is also unrequired. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 11, 2009 Share Posted September 11, 2009 If in doubt NGK have a superb technical help line for this sort of question. They recommended a surface discharge plug for my 600 BHP RB26 Skyline engine. Quote Link to comment Share on other sites More sharing options...
