J-spec TT Ecu location
hadyn
1bar = 1.02 kg/cm²
A stock Supe should hit fuel cut if the boost went above 1 bar for more than a sec or two.
Have you checked for a FCD yet? Also check for unusual stickers on the ECU. "MINES" for example.
right just lifted the cover which has exposed the gearbox and engine ECU.
No add on wiring, no sign of an FCD and no stickers on the ECU apart from the Toyota Denso ones. Althougth the top of the harness does have some grey tape that doesnt look factory on it. So why wont my car hit fuel cut @ 1bar? I've over boosted before and had a softer sensation like when you hit the speed limiter, but from what i've heard fuel cut should be like hitting a brick wall at high speed
