Hodge's (The Kraken) Supra build
hodge
  • Replies 4.9k
Posted Images
This really is fast becoming my favorite super ever!
Honestly Hodge, that a remarkable Supra. Keep up the good work
Thanks edd. thats very kind of you mate.
my plan is ive got another 11 days off work so im going to hammer the car and get as much done on it as pos. I hopefully want to get to the stage where its on the vurge of firing. I wonder if santa will bring me a Syvecs for Xmas:eyebrows:
Spent all day today undersealing the car again. Whilst I had the wheels off gave them a good clean and polish.
Some parcels arrived today too which means I can crack on with those.
1 of the Turbosmart BOV's.
Defi pressure harness.
Defi warning indicator
-3AN fitting for turbo Vacuum
-12AN bulkhead fitting for breather kit
Oil Temp sensor and plug for solaris.
I'll stick some pics up later on.
gorgeous picture mate, now screen saver
Certainly is mate it's on as my desktop already.
Looks awsome. :)
Cheers Lee. Means a lot coming from yourself.
looks mint mate, you will need an indicator or bumper or wing but for MOT.(unless you know a friendly guy)..
Yeah I've got a friendly MOT station I use. After it's painted though I'm going to fit some carbon Ganadors with indicators in them.
I can see the emissions being a little bit high too lol.
Those wheels look like they are gonna be a bitch to clean lol.
Have you thought about using a product called nanolex to seal the wheels? One of my mates has it done and makes the wheels really easy to keep clean :)
I've said it before and i'll say it again, this is my favorite car on the forum :)
Love it:cool:
Thanks Jamie. As I said about Lees post means a lot coming from you guys.
Your telling me. They took about 2hrs with some auto glym deep shine to get them like that. They were covered in dust from the filler n grinding dust etc. Good as new now. I do think I should look into something to coat them with to make them easier to clean though. It's a must I recon
That stuff is a little on the pricey side but well worth it if you ask me. My cars going in to get a once over in the stuff for winter. MarcAb10 has already had his done and its brilliant stuff. Meant to last 2years!
How much is it then, and I'm sitting down so I don't fall over;)
Been back in the garage tonight again.:)
Ive fitted the oil temp sensor for the solaris,
Made up and fitted the harness to passanger footwell
Fitted new oil pressure signal wire for the Defi oil pressure,
Wired in and fitted Defi Warning indicator to dash,
and finally put all the dash back together again and had the ignition on the check all the curcuits are correct.
Whilst i was in the car I noticed the clutch was getting spongey again, totally gutted cos it took me and Bossco a full day to bleed this off after the issues we had with it, I crawled back under the car expecting the worse. hinks wernt as bad as thought really. It seems to be weeping slightly from the bleed nipple which odviously is slowly letting it lose pressure. Hopefully ill have this all sorted by tomorrow.
Ive also started looking at the breather system and decided the following.
Ill have 2 -12an lines running from the cam covers to the inner wing. I have 2 bulkhead fittings im going to fit into the inner wing so I can attach the other end of the -12an braided line. On the other side of the bulkhead fittings inside the wing, ill run both lines down to a catch tank inside the inner arch and have an atmospheric vent of the other side of the tank.
Heres a few pics of tonights escapades.
Oil temp sensor.
fittings for big breather system.
This is where the bulkhead fittings are going to go.
Fittings on cam covers
This is aproximatly where the 1st BOV is going to go.
gave the engine bay a polish
http://i200.photobucket.com/albums/aa74/hodge_012/014-28.jpg[/img</p><p> </p><p> </p><p> </p><p> </p><p> </p><p> And back to this 1 cos I like it <img src=
http://i200.photobucket.com/albums/aa74/hodge_012/001-36.jpg' alt='001-36.jpg'>
More updates tomorrow hopefully.
This topic is now closed to further replies.
