Mugello Posted May 13, 2013 Share Posted May 13, 2013 I hope you get this sorted Im sure you will. Link to comment Share on other sites More sharing options...
hodge Posted May 13, 2013 Author Share Posted May 13, 2013 Well everything is pointing towards the cam sensor wiring so fingers crossed its an easy fix. Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 13, 2013 Share Posted May 13, 2013 Just measure the resistance across the cam sensor connectors at the ecu plug, and compare with the sensor itself, on the engine, or a spare one. You can just run a separate cable to the cam sensor and back to the ecu (screened). If you are on a mission I am bound to have some I can send you. Link to comment Share on other sites More sharing options...
hodge Posted May 13, 2013 Author Share Posted May 13, 2013 Just measure the resistance across the cam sensor connectors at the ecu plug, and compare with the sensor itself, on the engine, or a spare one. You can just run a separate cable to the cam sensor and back to the ecu (screened). If you are on a mission I am bound to have some I can send you. That's the plan of attack Chris's. it does make sense though, I've a feeling 1 of my connections I soldered have came loose or fractured. Ryan confirmed that the pumps will still run if the signal from the cam sensor is corrupt but it stops the pump if its the crank sensor. Link to comment Share on other sites More sharing options...
mellonman Posted May 14, 2013 Share Posted May 14, 2013 you can just do the same for every wire you suspect to be bad , unplug put meter one end put meter the other set to ohms and see what you get , if the leads are not long enough put one end to earth and then put the meter on the other end and then the other end of the meter to earth as well and see what you get. i bet you already know that but just making sure Link to comment Share on other sites More sharing options...
hodge Posted May 16, 2013 Author Share Posted May 16, 2013 you can just do the same for every wire you suspect to be bad , unplug put meter one end put meter the other set to ohms and see what you get , if the leads are not long enough put one end to earth and then put the meter on the other end and then the other end of the meter to earth as well and see what you get. i bet you already know that but just making sure Yeah thanks bud. I'm going to have a look at it tomorrow so fingers crossed I get it nailed with little trouble. I'll update tomorrow if I'm not in the huff that I couldn't get it going haha. Link to comment Share on other sites More sharing options...
hodge Posted May 17, 2013 Author Share Posted May 17, 2013 It's alive!!!! Bloody dodge TPS signal wire of all things. Even though Ryan is in Moscow he's been firing me emails through most of the day. Syvecs customer service freakin ROCKS!!!!! Link to comment Share on other sites More sharing options...
listy Posted May 17, 2013 Share Posted May 17, 2013 It's alive!!!! Bloody dodge TPS signal wire of all things. Even though Ryan is in Moscow he's been firing me emails through most of the day. Syvecs customer service freakin ROCKS!!!!! Link to comment Share on other sites More sharing options...
mclarenross Posted May 17, 2013 Share Posted May 17, 2013 very happy for you Link to comment Share on other sites More sharing options...
Hartmann Posted May 17, 2013 Share Posted May 17, 2013 happy days bud Ryan is the man ! Link to comment Share on other sites More sharing options...
clay Posted May 17, 2013 Share Posted May 17, 2013 I bet your well happy. Glade you got it sorted mate. And Ryan is a top bloke. Link to comment Share on other sites More sharing options...
Kev.O Posted May 18, 2013 Share Posted May 18, 2013 Great news Hodge! Link to comment Share on other sites More sharing options...
mellonman Posted May 18, 2013 Share Posted May 18, 2013 Sweet great news , hope it was not that much of a pig to find Link to comment Share on other sites More sharing options...
Jos Posted May 18, 2013 Share Posted May 18, 2013 Glad to hear!, must be a relief to finally have it running again! Link to comment Share on other sites More sharing options...
hodge Posted May 18, 2013 Author Share Posted May 18, 2013 Sweet great news , hope it was not that much of a pig to find Believe it or not I just stumbled across it. I plugged the laptop in and noticed the TPS1 signal on Scal was at 90% which is 90% throttle open. No matter if I pushed the pedal, the position didn't change. So another quick email to Ryan and he explained that if the Syvecs thinks the throttle is at 90% it won't put any fuel it because it has a built in anti-flood strategy. I dug the wire out, a quick temporary fix and she fired straight up. Link to comment Share on other sites More sharing options...
Stevo Posted May 18, 2013 Share Posted May 18, 2013 Kraken stuff! Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted May 18, 2013 Share Posted May 18, 2013 Brilliant John! great news bud Link to comment Share on other sites More sharing options...
hodge Posted May 18, 2013 Author Share Posted May 18, 2013 Kraken stuff! Very good lol Brilliant John! great news bud Thanks Rob. I'm still going to pull the whole wire out the loom and replace it, so were not out of the woods yet lol. Link to comment Share on other sites More sharing options...
Luxluc Posted May 18, 2013 Share Posted May 18, 2013 Congrats John. Ryan is a top bloke .. he quickly passes by next Tuesday to road map my Supra, so I can run it in properly before dyno mapping. Link to comment Share on other sites More sharing options...
hodge Posted May 18, 2013 Author Share Posted May 18, 2013 Congrats John. Ryan is a top bloke .. he quickly passes by next Tuesday to road map my Supra, so I can run it in properly before dyno mapping. I'm just using my old map to run it in. The AFRs were perfect on fire up and when it was running. I'll keep it to below 4K and all should be good. Link to comment Share on other sites More sharing options...
hodge Posted May 18, 2013 Author Share Posted May 18, 2013 I'll tidied up all the wiring now, replaced the damaged TPS wire and now everything is tucked away neatly under the ECU cover. I'm off out for a drink with the lads tonight so tomorrow afternoon I've got another couple of very quick jobs to do and then she's almost ready for the road. Link to comment Share on other sites More sharing options...
Kaan W Posted May 18, 2013 Share Posted May 18, 2013 Nice to see everything's come together now, well done mate Link to comment Share on other sites More sharing options...
DaveR Posted May 19, 2013 Share Posted May 19, 2013 I'll tidied up all the wiring now, replaced the damaged TPS wire and now everything is tucked away neatly under the ECU cover. I'm off out for a drink with the lads tonight so tomorrow afternoon I've got another couple of very quick jobs to do and then she's almost ready for the road. Yeah baby! Can't wait to see all of the "she's finished" pics and all of the following magazine features. Link to comment Share on other sites More sharing options...
hodge Posted May 19, 2013 Author Share Posted May 19, 2013 Nice to see everything's come together now, well done mate Yeah baby! Can't wait to see all of the "she's finished" pics and all of the following magazine features. Thanks guys. Well I was all intending going out and doing a little work on her today, but unfortunately I've just crawled out of bed after a very good night out in Newcastle. After 2 bottles of champagne and stupid amounts of cocktails, I was pretty much Ill this morning so the garage door is staying shut. Link to comment Share on other sites More sharing options...
Luxluc Posted May 19, 2013 Share Posted May 19, 2013 (edited) I'm just using my old map to run it in. The AFRs were perfect on fire up and when it was running. I'll keep it to below 4K and all should be good. Mine runs quite unstable...2000cc injectors replaced 850, Syvec ecu replaces AEM, 280cams instead of 264. During run in, the revs needs to be pushed progressively up. Ryan will check to make sure everthing is OK. Edited May 19, 2013 by Luxluc (see edit history) Link to comment Share on other sites More sharing options...
