hodge Posted June 23, 2011 Author Share Posted June 23, 2011 (edited) ID1000 injectors turned up today. Unfortunately they didn't fit the intake runners on my Veilside plenum. The rail side was fine using the adaptors but the runner side was no where near. The O-ring was too narrowband wasn't sealing on the runner. So a little adaptation was required. I didn't really fancy drilling out the runners so I thought I'd try and use the O-rings from my old injectors as they were wider and thicker. This seemed to seal them nicely against the bottom of the injector bore in the runner. The only sure way to tell though will be when it's running I suppose. Here's some pics of how I did it all. Firstly the plenum runners still with injectors fitted. Rail fitted with new adaptor buckets. On the right is the O-ring from the Injector Dynamics injector and the left is from my old RC injectors. And here they are on the injectors. And here's all 6 with the bigger O-rings on. Injectors and rail fitted to the runners. The injectors turned out to be slightly longer than the RCs so I needed a washer to lift it a little to stop the upper O-ring loosing it's seal. Edited June 23, 2011 by johnny g (see edit history) Link to comment Share on other sites More sharing options...
johnny g Posted June 23, 2011 Share Posted June 23, 2011 Very tidy those mate. Will be super keen to see how they pan out for you Link to comment Share on other sites More sharing options...
hodge Posted June 24, 2011 Author Share Posted June 24, 2011 Very tidy those mate. Will be super keen to see how they pan out for you You and me both "G". There very very thin which I was very suprised about. The ones I've had previously have a larger part in the middle but these are tiny little things. They look like something from the pound shop lol. Hopefully my new Blue Titanium bolts will arrive today so I can get it all bolted back together tonight. Think it's going to be a VERY late night again tonight. Link to comment Share on other sites More sharing options...
Guest NDIDDYSCHICK Posted June 24, 2011 Share Posted June 24, 2011 (edited) Absolutely loving your build thread mate. Been keeping an eye on this one for some time now and decided I had to comment. Loving how you are doing most of the work yourself, and to such a high standard as well. Great taste. EDIT: Edited June 24, 2011 by NDIDDYSCHICK (see edit history) Link to comment Share on other sites More sharing options...
hodge Posted June 24, 2011 Author Share Posted June 24, 2011 Absolutely loving your build thread mate. Been keeping an eye on this one for some time now and decided I had to comment. Loving how you are doing most of the work yourself, and to such a high standard as well. Great taste. Question thou; i've noticed (well i think im looking at this correctly ) you have kept the pressure surge tank. Any reason why you haven't removed it? (The tank on the right hand side of this pic?) That's the starter motor dude. Link to comment Share on other sites More sharing options...
Guest NDIDDYSCHICK Posted June 24, 2011 Share Posted June 24, 2011 haha didnt think I was looking at that correctly (still learning the car mechanics) nice build none the less Link to comment Share on other sites More sharing options...
hodge Posted June 24, 2011 Author Share Posted June 24, 2011 Cheers bud. I'm hoping to get it running again this weekend if my titanium bolts show up for the runners. Link to comment Share on other sites More sharing options...
Guest ugp Posted June 24, 2011 Share Posted June 24, 2011 Looking good mate, when's it off for paint? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 24, 2011 Share Posted June 24, 2011 Cheers bud. I'm hoping to get it running again this weekend if my titanium bolts show up for the runners. Flash Git!! lmao. nice update john them injectors look cool Link to comment Share on other sites More sharing options...
hodge Posted June 24, 2011 Author Share Posted June 24, 2011 Looking good mate, when's it off for paint? 4th of July mate. Lots to do before then. Flash Git!! lmao. nice update john them injectors look cool I get all my titanium bolts for free the pro bolt guy just puts them through as promotion :-) plus he owes me a favour or 2. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 24, 2011 Share Posted June 24, 2011 Free titanium bolts nice work john, the little touches go along way Link to comment Share on other sites More sharing options...
hodge Posted June 24, 2011 Author Share Posted June 24, 2011 Free titanium bolts nice work john, the little touches go along way Certainly do bud. Things arecertainly moving on now. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 24, 2011 Share Posted June 24, 2011 Certainly do bud. Things arecertainly moving on now. i remember hearing you say that in november time last year, looks the business and should go like stink. Link to comment Share on other sites More sharing options...
hodge Posted June 25, 2011 Author Share Posted June 25, 2011 (edited) After lee pointing out the heat generated from the engine mount brackets I've heat wrapped the FPR. He explained there has been a few issues with supras in the states with fuel pressure fluctuation caused by heating of fuel in the engine bay so I thought I would be better safe than sorry really. I've done all the top where the pressure adjustment is and put a few layers on the back where it bolts to the mount bracket. This is how it looks mounted. This is how it sits with the plenum in place. I'm over the moon with it as it's tucked away but still easy to access to alter the pressure. Idle control valve has been stripped down, cleaned, powder coated and put back together. This is how it looks fitted to the underside of the plenum. This pic shows where the engine loom enters the cabin in it's new position. More updates later on today. Edited June 25, 2011 by hodge (see edit history) Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 25, 2011 Share Posted June 25, 2011 that idle control valve looks neat. does it cost alot to powder coat mate? Link to comment Share on other sites More sharing options...
hodge Posted June 25, 2011 Author Share Posted June 25, 2011 that idle control valve looks neat. does it cost alot to powder coat mate? I've got a top notch powder coater about 10 miles up the road from me. I don't think it's that expensive for what you get really. I got a top water elbow and the idle control valve done and he charges 30 quid which was masking them off, sand blasting then and then coating them. Quick turnaround too. I've known the guy for a while and he tends to squeeze my work through quickly. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted June 25, 2011 Share Posted June 25, 2011 nice one. i might shoot some bits up to you if thats ok Link to comment Share on other sites More sharing options...
hodge Posted June 25, 2011 Author Share Posted June 25, 2011 nice one. i might shoot some bits up to you if thats ok How did I know that was coming lol. Link to comment Share on other sites More sharing options...
Westy Posted June 25, 2011 Share Posted June 25, 2011 I bet your missus sees the sense in building...then taking apart...then re building again! Link to comment Share on other sites More sharing options...
hodge Posted June 25, 2011 Author Share Posted June 25, 2011 I bet your missus sees the sense in building...then taking apart...then re building again! She's not interested in the slightest Nate to be honest. I could have built a time machine in there and she wouldn't have noticed. Link to comment Share on other sites More sharing options...
Geo Posted June 25, 2011 Share Posted June 25, 2011 She's not interested in the slightest Nate to be honest. I could have built a time machine in there and she wouldn't have noticed. but if you had build a money printing machine, she'd be bring you cups of tea and food so you could work 24/7 Link to comment Share on other sites More sharing options...
hodge Posted June 25, 2011 Author Share Posted June 25, 2011 but if you had build a money printing machine, she'd be bring you cups of tea and food so you could work 24/7 Funny how that works ain't it lol. Link to comment Share on other sites More sharing options...
scotty71 Posted June 25, 2011 Share Posted June 25, 2011 I bet she is none the wiser on the cost either Link to comment Share on other sites More sharing options...
hodge Posted June 25, 2011 Author Share Posted June 25, 2011 I bet she is none the wiser on the cost either Shes not daft lol. she knows exactly how much ive spent. I dont drink or smoke and she has 3 holidays a year so she cant moan really. Link to comment Share on other sites More sharing options...
David P Posted June 25, 2011 Share Posted June 25, 2011 Shes not daft lol. she knows exactly how much ive spent. I dont drink or smoke and she has 3 holidays a year so she cant moan really. Does she send you a postcard. Link to comment Share on other sites More sharing options...
